Msd Connection Problem!
Old May 28, 2006 | 06:07 PM
E46Kid's Avatar
Default Msd Connection Problem!
I have a msd kit and was wondering if i run two new wires on the pickup coil and cut the wires outta the harness inside the distributer that goes to the old ignition coil.
Old May 28, 2006 | 07:30 PM
E46Kid's Avatar
1 hour bump!
Old May 28, 2006 | 08:45 PM
fmrprojects's Avatar
Default Re: (EkSi)
you remove the stock coil from the distributor and run the pos and neg wire to the msd box
Old May 29, 2006 | 01:03 AM
hatchi's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">you remove the stock coil from the distributor and run the pos and neg wire to the msd box</TD></TR></TABLE>
Old May 29, 2006 | 01:19 AM
E46Kid's Avatar
Default Re: (hatchi)
so i just remove it completely? im confused..wouldnt the injectors need to know when to fire?
Old May 29, 2006 | 04:55 AM
No-Gi's Avatar
Default Re: (EkSi)
YOu need to remove the coil. Then run the two wires outside
redlinez_r_us
May 28, 2010 12:05 PM
d16rice
12
Mar 23, 2005 03:41 PM
NitrousB.I.G.
Dec 22, 2004 07:06 PM
turboITR#704
Jun 6, 2003 11:17 AM
RAWB
Aug 20, 2002 06:36 PM
