Check engine light on/off so is the oil light
Old May 28, 2006 | 06:03 PM
HONCORD's Avatar
Default Check engine light on/off so is the oil light
I just replaced my 02 sensor. Light went off right away. But came back on 2 days later. If I turn off my car and restart it. It goes away again for 4-5 day then back on again. Whats going on?
Second. My oil light does the same thing it comes on and starts blinking. If I shut the car off and then restart it it goes away for a week then back on.
Is it my oil sending unit going bad or what?
Old May 28, 2006 | 07:35 PM
ujhonda's Avatar
Default Re: Check engine light on/off so is the oil light (HONCORD)
I have a Helm manual; yes it says to check/replace sending unit for your Oil light issue.
now you already replaced the O2 sensor, I think time to check your pcv valve too. then reset the ECU. you should be Ok unless some other issues with your car.
Old May 28, 2006 | 08:10 PM
hondadude's Avatar
What code are you getting that led you to change the O2 sensor?
Old May 28, 2006 | 08:11 PM
HONCORD's Avatar
Default Re: Check engine light on/off so is the oil light (ujhonda)
I checked the pcv, its still good. My car got only 54k miles on it. I did disconnect the battery to reset my ECU. But problem still stands.
EJAYATE
Jan 13, 2010 01:46 PM
FOMULA91
Aug 14, 2007 01:50 PM
Groove_D
Jan 4, 2005 01:13 PM
Cashflo
Oct 25, 2003 09:00 AM
Mrfirefox
May 6, 2002 12:47 PM
