Polishing vavle cover?
Not sure if this goes here or not. I have a DA (All stock motor) I was wondering if I can polish my vavle cover...I want to do something with it, either in the line of painting it, or polishing it. Is it possible to polish it, can i sand the ?humps? (not sure how to word it) flat to get a even surface?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N.O.R.E »</TD></TR><TR><TD CLASS="quote">Not sure if this goes here or not. I have a DA (All stock motor) I was wondering if I can polish my vavle cover...I want to do something with it, either in the line of painting it, or polishing it. Is it possible to polish it, can i sand the ?humps? (not sure how to word it) flat to get a even surface?</TD></TR></TABLE>
Sure you can polish it, but you can't get rid of the "humps." You could alternately buy a '96+ B18B or B20B/Z valve cover and polish that if you're looking for a smoother look.
you can polish it, its a pain in the ***, right now I am in the works of polishing a gsr valve cover, it looks good so far, but I still have a ton of work left
i wouldnt do it. it is a super pain in the ***. i would recommend painting it. i use to have mine polished but i painted it cause it get dull lookin, but it turned out great painted
and here's a better pic of the fitting/hole you'd have to plug
Either get some kind of rubber plug, or have that plastic elbow in there with something over the end.
polishing is a nice touch if you can keep it up but it's honestly the most tedious thing i've ever dealt with, even on a set of wheels, i couldn;t imagine it in the endinge bay. But if you get it bead blasted you can sand it smooth and polish it
yeah i polished my hx rims and that took me two days...its nearly impossible to sand it down with a sander..had to do it all by hand...i bought the sander but never really got to use it...thats why i wanted to give my valve cover a try
i did my special edition last summer and took me i say a good 5 or more days to do thats takin off the old paint a whole lot of sanding, plenty of paint stages, and plenty of clearcoat.. over the weekend i did my valve cover took 2 days to do.. I guess I'm just a bit **** when it comes to things like that, definetly need a whole lot of patience and elbow grease and once its done its all worth it
i polished my A20 Valve cover last winter... it took a good 3 days of sanding i did it by hand ( no dremel) just spray on the aircraft remover and leave it ...it just wipesoff. after sanding the F*(K out of it.. use Mothers Polish and buff it .. the more you buff the shiner it gets.. i give major props to a guy that does it its not an easy job .. makes painting looks like ***** wrk
GroundZer0 336
Dec 19, 2004 05:21 PM
