Exhaust system's for 94 Civic Hb..... hybrid suggestions
i have a Gsr motor in my 94 Hb. what's a bolt on exhust without modification. as far as cutting the b pipe? any headers.... with cat. combination?
ITR manifold, ITR cat, ITR b pipe, Si axle-back
GSR manifold, GSR cat, Si cat-back.
del Sol VTEC manifold, Si cat, Si cat-back.
[Modified by SkyeC, 12:48 AM 4/14/2002]
Problem with the B18C1 swaps is that the exhaust manifold/cat combo is a good 3 inches shorter then your stock set-up.
Just extend an exhaust - it's very cheap and easy to do.
thanks for the offer. i got a tanabe rm. already. im running the set up of a 93 gsr header and 90 cat. with my exhuast it's bolt on extened out a little. thanks for the help everyone.
is that correct??? thanks
TTT
can someone answer my question about if the b18c1 stock header, gsr cat, and apexi n1 exhaust will bolt up and not require an extension of the exhaust pipe?? thanks
Mr Boston
Feb 22, 2004 07:30 AM
