Question ab out headlight
Ight i tried to search but dont know what to call this so ok here we go. I just put my hids in from a G35 everything looks good and all but it doesnt look like it projects as far as it should here is what i think the prob is
could the round thing in the middle be the problem its in front of the light so that is what i am thinking. Sorry dont know the name of it just never had a reason to know i guess lol
Here are some other pics of headlights and stuff
on during the day
mounting thinking about changing it anyone have any idea of any better place?
on during the day
The reason they suck at night is cause you don't have projectors in your headlights. Prelude headlight housings were not designed to have HIDs, so what people, inlucding myself, will do is called Retrofits. There are plenty of topics about this, just have to use the SEARCH function.
well man thanks for not helping but toke the little guards and looks a thousand times better so if you havent tried something before please dont post thanks
you shouldn't make nasty replys without fully knowning what you are talking about. you need the hid projectors to have the light the right way, the amount of glare you have coming off your car must be immense. plz post some pics of the beam pattern, im curious.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustinsjdmlude »</TD></TR><TR><TD CLASS="quote">well man thanks for not helping but toke the little guards and looks a thousand times better so if you havent tried something before please dont post thanks</TD></TR></TABLE>
As a matter of fact I have ran HIDs without those little sheilds, and the lighting still look like **** cause it was focusing everywhere but the street like they're suppose to be and had major glare. If you use the SEARCH function, you'll realize that putting projectors will be 100x's better than just having HID bulbs put in. I bet on coming traffic loves you for blinding them
For example, check this thread out https://honda-tech.com/zerothread/1643009 or http://www.imagestation.com/pi...3.jpg cause that is how your lights should look like
Saying that Brian doesn't know anything about headlights is like saying that... something, whatever.
But he knows his ****, he did my retrofit and it turned out all kinds of great
WOW.....So you're basically running non-projected HID's in a high-beam set up blinding the expletive out of people.
Great Job
Half-assed HID's FTL
Invest some money and do it right!
Great Job
Half-assed HID's FTLInvest some money and do it right!
d2r bulbs are for use in reflected housings and it looks alright. But the fact is even with those bulbs the prelude housing isn't meant to focus HID light the right way, the bulb sits in a different spot. The only RIGHT way to do an HID setup is a projector retrofit.
And are you running a new relay harness or off the stock headlight harness... If not you need to be running a new harness to ensure your ballasts pull a constant amount of the right voltage otherwise things could go bad.
Hybridcrx469
Nov 8, 2004 04:27 PM
