Rubbing??????
Old Apr 13, 2002 | 08:34 PM
95CoupinIt's Avatar
Default Rubbing??????
I have 17 X 7.5 in wheels with 40 mm offset and 205/40 series tires on my 1995 civic coupe. I am gonna be getting H & R sport (1.7" drop) springs and KYB AGX adjustables for the shock setup. Do you think it will rub? and does anyone else have any ideas for me. thanks.
i am going to be using this as a daily driver, wont see the track or strip unfortunately. strictly street
Old Apr 13, 2002 | 09:17 PM
azhatch's Avatar
Default Re: Rubbing?????? (95CoupinIt)
i have a 1.8 drop by eibach, stock shocks and 17x7 205/40s. i rub around tight corners and definately when braking and turning at the same time. 00' civic 4dr. i think you will rub worse than i do, i'm looking for smaller wheels already.
Old Apr 14, 2002 | 01:07 AM
Dustorm's Avatar
I think that you should be fine. Especially with the new struts. I had my civic on 17X7 Enkie RS6's and ground control coilovers...i think i had it dropped a little over 1.6 in the front and like 1.7-2 in the rear and i only rubbed when i would hit a corner really hard or hit a corner that had a dip in it. Other than that everything was kosher!
StraussBuster
10
Oct 19, 2013 09:22 PM
07gen8Civic
Suspension & Brakes
Jun 13, 2009 05:52 PM
mikeunreal2
Jan 11, 2007 05:09 PM
Nathan007
Apr 18, 2006 10:56 AM
97F22B2
Dec 14, 2003 05:01 AM
