99 si ecu???
so im runnin greddy turbo on stock internals but i need to get a p28 ecu. i found one on jdmshit.com but it says its for 92-95 civic...i was told any p28 would work. would this one work?? http://www.jdmshit.com/ecu/index.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.EGg »</TD></TR><TR><TD CLASS="quote">you would need the obd2b-obd1 jumper harness to run it in your SI. and then get the p28 chipped/tuned for the setup</TD></TR></TABLE>
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicksiguy »</TD></TR><TR><TD CLASS="quote">where can i get the cheapest one?? or will the one on the link work??</TD></TR></TABLE>
The one in the link you can get (OBD-2 Ver.2 --> OBD-1 (99-01 cars)). Seems like a reasonable price.
x2
Brand New JDMsh!t ECU Adapter Harness
OBD-2 Ver.1 --> OBD-1 (96-98 cars)
$75 shipped
and the ecu will work with the adapter harness. also check to see if the set up is for a DOHC not SOHC
$75 shipped
Untamed_Hatred
Jan 29, 2008 05:02 PM
stw88crx
Nov 10, 2004 01:24 AM
