My car won't start when it's HOT outside!!??
I left my house this morning when it was cool outside. Didn't have a problem. This afternoon though when the temperature was at it's peak the car was turning but not starting. Last summer it happened sometimes but I would wait a few minutes and it would start after. Would I need a tune up? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deo »</TD></TR><TR><TD CLASS="quote">Most likely the Main Relay, easy fix. Search it for a guide.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nostreble »</TD></TR><TR><TD CLASS="quote">if its the main relay, just let some air inside the car too cool down.</TD></TR></TABLE>
only works *sometimes*. Mine had the same problem.
I found if i sat there cycling the key to on / off / on / off eventually it would work, but then i had to change my ign switch. so, replace the relay, lol.
It is definetly the main relay. Detailed problems and a fix can be found here: http://www.tegger.com/hondafaq/faq.html#startrun
Soldering is very easy on this! I've done mine, and no longer have problems! Give it a shot!!!
89sicivic
21
Jun 21, 2006 02:00 PM
DXDOHCVTEC
13
Apr 20, 2005 04:57 AM
