91 hatch std. wiring problem
Ok, here is the problem, my car was running fine but my radio wasnt comming on, so i went under the dash to see if a fuse was blown. One looked blown from the side so i plucked it, instanly my car dies. So i was confused, so i replace the fuse and then the car still doesn't start, after a few hours i find that there is no spark, so i start troubleshooting parts, i changed the ecu, ignition switch, all fuses, ignitor in the distributor, and also checked all the fuses dash/hood and the main relay the way the haynes manual tells you to all with no luck. So right now i am up **** creek with no paddle, and got to be to work tuesday. anyone with any ideas?
93eg2james
17
Dec 16, 2006 08:15 AM
drtyhatch
13
Dec 14, 2005 04:43 AM
