jumper harness?
OBD1 H22 motor in a 90' accord. Need computer harness to install a OBD1 computer to run the H22. Also if anyone knows we need to buy a harness for the motor to the car. Any sugestions welcome. I have looked at Hasport.com and on Lightningmotorsports.com for the harness with no luck.
You actually just use your Accord harness and add the plugs that you need. The P13 ECU from the H22A will use the plugs already in your car from the Accord harness.
Check the swap guide for more info on what you need to add.
So you are saying to use the Accord 90' motor harness on the H22 and just add the wires and plugs to there proper spot? I have both harnesses OBD2 H22 and the OBD0 F22. We have all new mounts,flywheel and clutch ***,full timing belt service,tensioner fix, and 2 ECU's. Thanks for the response. If you have anything else to add that would be awesome. Can't wait to get it done. Just don't want wiring nightmare.
i know how to search for sh%t. Don't play with me. I was just checking around for underground info. I have a Ultimate Swap Guide by Nathan Morris!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapsshonda »</TD></TR><TR><TD CLASS="quote">i know how to search for sh%t. Don't play with me. I was just checking around for underground info. I have a Ultimate Swap Guide by Nathan Morris!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I never said anything about your ability to search, nor was I playing with you.
Underground info? I'm not sure what in the hell would be considered "underground info". Maybe you've been playing too much Need for Speed: Underground or something.
</TD></TR></TABLE>I never said anything about your ability to search, nor was I playing with you.
i love fast and the furious. And spoilers with altezzas. NOT. I putting a OBD2 H22 in 90' Accord. That is for racing. No more Arguing. I have alot of wires to cut and really want to be sure it's done right. Have a good one.
Look, what you want to do is make sure you know what every single plug is before you pull it off of your 90. Mark every single one. Then throw in the H22A and look to see what every single plug goes to. Having both service manuals will help with this. Then you can look around the H22A block and you will see connections with no plug. These are the ones you must add.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapsshonda »</TD></TR><TR><TD CLASS="quote">No more Arguing.... Have a good one.</TD></TR></TABLE>
I wasn't even arguing, but oh well. Good luck with your swap.
I will post pictures after I'm finished. The SWAP should go smoothly. I have done 1 or 2. Haha. No seriously . . . I will post some pics. No big deal. We are all trying to bang VTECH!
