h22 eg mount question
Old May 28, 2006 | 10:23 AM
makelove2hondas's Avatar
Default h22 eg mount question
I have a big vibration under decel I noticed after I put the H22a in the car. Well to come find out the engine wasn't sitting level, the passenger side was sitting really low. The engine would raise up like 2 inches on the passenger side under accel and come up to where its suppose to be, the vibration stoped under accel. I have the hasport mounts I believe they are the EGH1 mounts, I bought them off of a friend. I raised the transmission up to where its suppose to be and tightend the mount on the trans, seems to be level now. I was wondering how many bolts do you guys have holding the plate to the transmission for the mount. Here is a picture of mine:
Old May 29, 2006 | 06:48 AM
Default Re: h22 eg mount question (makelove2hondas)
anybody know anything about that hole at the bottom?
Old May 29, 2006 | 05:55 PM
lak8's Avatar
Well i have hcp mounts. I guessing they would all be the same since there all roughly close in design for bolting it on the engine itself. The hcp mounts use 3 bolts on the transmission to hold that bracket. hope that helps
Old May 30, 2006 | 01:25 PM
aeolus's Avatar
Default Re: h22 eg mount question (lak8)
its suppposed to be bolted with three bolts.From the looks of it,u could have certain accord transmission where one of the bolt holes won't line up.Ive seen this happen before.
Old May 30, 2006 | 01:57 PM
Default Re: h22 eg mount question (aeolus)
The hole without the bolt is there suppose to be threads in it becasue I cannot find any?
Old May 30, 2006 | 03:42 PM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">its suppposed to be bolted with three bolts.From the looks of it,u could have certain accord transmission where one of the bolt holes won't line up.Ive seen this happen before.</TD></TR></TABLE>
yup three bolts, although i utilize an accord bell housing and don't have an issue
Old May 30, 2006 | 04:14 PM
aeolus's Avatar
if its a prelude tranny,there should be some threads,if not,its a good chance the hole wont line up.whats the code on your transmission?
Old May 31, 2006 | 08:27 AM
Where is the code located at?
Old May 31, 2006 | 09:42 AM
aeolus's Avatar
on the bell housing
Old Jun 3, 2006 | 02:29 PM
its either a m2a4 or m2 b4 so is there suppose to be a bolt in that empty hole at the bottom of the page?
Old Jun 6, 2006 | 08:30 AM
nobody eh?
Old Jun 6, 2006 | 08:55 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makelove2hondas &raquo;</TD></TR><TR><TD CLASS="quote">nobody eh?</TD></TR></TABLE>
is there a threaded hole in the tranny that lines up with the hole on mount?
Old Jun 6, 2006 | 01:47 PM
v4lu3s's Avatar
RTFM
all prelude trannies will ahve bolt holes to match those 3 holes in the mount.
92-93 accord trannies will have a hole that needs ot be tapped right there, while 94 accord up trannies will have a threaded hole there.
90-91 accord trannies will have no hole there at all.
if you got an m2XX tranny then the case has been swapped if it doesnt line up to a threaded hole.
Old Jun 7, 2006 | 02:49 AM
Default Re: (v4lu3s)
it lines up to a hole in the case but i can't see down in there good enough to see threads, partlly because of the clutch fluid line brack is right above it, i even tryed to move it. do you know the right size bolt, I could just try threading one down in there? thanks
Old Jun 7, 2006 | 04:01 AM
v4lu3s's Avatar
RTFM
its the same size as the other bolts used on the mount.
no luv
Aug 14, 2011 12:49 PM
dustinO
Sep 20, 2006 01:50 PM
nikolai.
Apr 28, 2006 06:11 AM
EsQueue
May 19, 2005 02:33 PM
dso
Dec 2, 2004 05:15 PM
