HELP BRAKES
Old May 28, 2006 | 10:17 AM
whitehf's Avatar
Default HELP BRAKES
i recently took off my brakes calipers to paint (front and rear)..wen i put the brakes back on they wouldnt work....when the engine is off theres a little more pressure on the pedal but once i start it the pedal gets really soft..my pedal is really soft, bleed the front, brake fluid is high...does anyone know what can be causing this??
Old May 28, 2006 | 10:19 AM
Lan's Avatar
Lan
Default Re: HELP BRAKES (whitehf)
Did you bleed them correctly?
Old May 28, 2006 | 10:30 AM
mr.beeks's Avatar
Default Re: HELP BRAKES (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">Did you bleed them correctly? </TD></TR></TABLE>
did you?
Old May 28, 2006 | 11:03 AM
whitehf's Avatar
Default Re: HELP BRAKES (mr.beeks)
yes i did..but i didnt bleed the back..wen i pull the ebrake its pretty tight..so im thinking the back works fine...
Old May 28, 2006 | 12:40 PM
Sam92Teg's Avatar
Your thinking wrong, the parking brake is cable actuated, nothing to do with the fluid in the lines. When they asked if you bled them properly, just say 'nope'.
Old May 29, 2006 | 10:00 AM
whitehf's Avatar
Default Re: HELP BRAKES (Sam92Teg)
okay i got my brakes to work..but they dont brake as well as they did before..and it kinda sinks in..so what can i do now??
CivicHP
Sep 30, 2005 01:32 PM
92 CIVIC HATCH VX
Feb 22, 2005 04:58 AM
Mike_C
Apr 1, 2004 11:18 AM
natrl
May 23, 2003 04:13 PM
