Air Leak near Intake.
I dont know, it could be. I have been having problems with Air getting into my engine. I have to purge the radiator everytime I drive. I was thinking it was a vaccum leak.
That sounds like a coolant problem if you have to purge your radiator. Have you checked your thermostat or replaced it? The noise you are hearing is most likely the fuel pump.
I just changed the coolant and the Idle Control valve. Its running a little better but there is a drop in pressure systematically. I cant figure that out, its like its skips a beat.
