do luck room bar owners pls help
Old May 28, 2006 | 05:00 AM
an2ny888's Avatar
Default do luck room bar owners pls help
i've been trying to install the do luck room bar that i recently bought from ebay, and i can't get the damn thing to fit! i know some of you guys have this bar, can you give me some tips on how to install it?
Old May 28, 2006 | 07:38 AM
94rs-turbo's Avatar
no clue what your talking about pics might help
Old May 28, 2006 | 06:54 PM
citrus3000psi's Avatar
Default Re: do luck room bar owners pls help (an2ny888)
Where doesn't it fit at?
A little more info.
For those who don't know:
Old May 28, 2006 | 06:59 PM
nightrider's Avatar
Default Re: do luck room bar owners pls help (RGoose18)
RGoose18, is there something wrong with the OP coming to HT for some help? you are being a dick for no reason.
Old May 28, 2006 | 08:02 PM
H-PIMP's Avatar
Default Re: do luck room bar owners pls help (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">RGoose18, is there something wrong with the OP coming to HT for some help? you are being a dick for no reason.</TD></TR></TABLE>
Welcome to the ITR forum. That type of attitude is nothing new around here. Boggles the mind to this day, how one Integra owner feels he's superior to another Integra owner.
To the OP, I wish I could help, but I have no experience with such part.
Old May 28, 2006 | 08:37 PM
fourcsan's Avatar
* B A N N E D *
maybe something to do with that support brace thingy? the big black one.
Old May 28, 2006 | 08:51 PM
RGoose18's Avatar
Easy buddy, it was just a joke, but I'm sure the pharmacy has more midol for that ***** ache of yours
Old May 28, 2006 | 09:59 PM
nautica_t's Avatar
i believe there should be adjustment ***** at near the middle for each side and they attach to the seat belt anchors on each side.
Old May 28, 2006 | 10:03 PM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">
Easy buddy, it was just a joke, but I'm sure the pharmacy has more midol for that ***** ache of yours </TD></TR></TABLE>
you really feel that your response was simply a joke? if at all anything, it was obvious you were trying to be a dick and are continuing to be a dick towards me for no reason. grow up.
Old May 28, 2006 | 10:40 PM
RagingAngel's Avatar
post pix or describe to us where exactly does it not fit?
I got mine to go in pretty easily after I chopped the carpet up a bit....
There have been others that say it can be installed without cutting up the carpet but to the best of my memory and looking at it somewhat recently, I can't see how you can get the two support legs (held in place with the seatbelt anchor bolts) in the proper position without having the carpet cut away.
EDIT: I suppose you could fold the carpet out of the way, but hell, that would look kinda nasty, but it wouldn't ruin the OEM'ness of it.... if you ever decided to remove the bar and return everything back to stock.
Old May 29, 2006 | 07:57 AM
an2ny888's Avatar
Default Re: do luck room bar owners pls help (RagingAngel)
tnx for the help guys, i'm just going to ignore the sarcastic *****. i'm trying to install it without cutting the carpet, that's why i'm having such a hard time. i was looking at it a while ago, and like you said, i also don't see how it will fit without cutting the carpeting up. raging angel, did you feel the bar made a difference?
Old May 29, 2006 | 10:36 AM
I installed the bar back in '98 when it had relatively low mileage and doesn't suffer the current creaks with an almost 10yr old ride.
At the time, I felt the only difference that could be felt was when I was cornering at illegal speeds.
that said, do-luck later on released "clamps" that would secure the center of the bar to the tunnel/"backbone" of the car.... an area I noticed no matter how much I tensioned still had some undesirable play.
unfortunately, I didn't have the courage (or money) back then to drill holes in my new car to try these clamps out....items I feel do-luck produced because they recognized their validity.
I think in your specific situation, you could try removing the carpet altogether or purchase a used one to chop up.
Old May 29, 2006 | 07:57 PM
an2ny888's Avatar
ok tnx a lot for the feedback, am off to cut my carpet
Old May 29, 2006 | 08:37 PM
vtir's Avatar
u gotta chop the carpet..
i tried mucking around with it for half a day and in the end i gave up n cut it
cut it deep enough to cut the backing plastic as well
Old May 29, 2006 | 11:44 PM
IntegraXTR's Avatar
i wonder if this bar will fit with my cusco cage..it might be in the way.
post pics of the bar installed! =P
Old May 30, 2006 | 05:25 AM
RaVAGE00's Avatar
New User
I have the same bar and had the same issue.
Solution: Take those damn nuts from the middle of the bar off. That shortens the bar enough and its fits perfect.
ITR010342
Mar 16, 2008 04:15 AM
BOTAN01
Nov 27, 2007 08:39 PM
disfilam04
Sep 27, 2007 03:12 PM
Lucky-R
Sep 6, 2004 09:04 AM
