watch it blink
Old May 27, 2006 | 07:41 PM
tht88hatch's Avatar
Default watch it blink
my 88 has a b16a2, running lean. my ecu will flash once when the car is switched to accessorie or on. Then it will flash four times is a row. does that mean once for o2 sensor then four more times for crank sensor? im 20 in az just feening for an opening in the car scene. anyone know good help around glendale?
Old May 27, 2006 | 07:44 PM
thevtecnician's Avatar
Default Re: watch it blink (tht88hatch)
The ecu blinking when you turn it on is indicating that the ecu is working. It will always blink once when u turn it on.if it doesn't you have a faulty ecu. You have a 3code not 4
Old May 27, 2006 | 08:32 PM
MrPotatoeHead's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tht88hatch &raquo;</TD></TR><TR><TD CLASS="quote">my 88 has a b16a2, running lean. my ecu will flash once when the car is switched to accessorie or on . Then it will flash four times is a row. does that mean once for o2 sensor then four more times for crank sensor? im 20 in az just feening for an opening in the car scene. anyone know good help around glendale?</TD></TR></TABLE>
You have a code 4...Not a 3 as stated above.
Old May 27, 2006 | 08:49 PM
Default Re: watch it blink (MrPotatoeHead)
My bad I read that wrong.
Sedwards1200
Sep 3, 2016 03:31 AM
BoostJockey
23
Feb 7, 2014 04:42 PM
ityab0y
Jun 13, 2005 05:35 AM
NH88TSI
Feb 7, 2004 08:59 AM
