Autometer Oil Pressure Gauge & Greddy Block Adaptor.....
hey everyone,
Just wanted some info on the 2 items and yes i have done a search and it seems like a question asked by alot of other members and i wasnt able to locate an answer.. My question is that i have gotten both items and have come to a dead end on what i can do to connect the 2 items together.. i know i have to use a SS Line to connect the sender unit to the block adaptor but if u havw seen the block adaptor the threads are not normal and i havent been able to find the items i need to connect both together.. so if someone has done it and would be willing to help me out with that part of the install... wires and guage are in but the only thing holding back is the connection of the sender unit and the block plate from greddy...
thanks
Modified by P0sTaL at 9:14 PM 5/27/2006
thanks
so you need the fitting for the block that goes into the line which then goes too the gauge? more than likely a 1/8npt thread... just like the GE .. you can get it from there site if u want and if someone can verify ityll work.. easiest way would be too call greddy for the specs
so i take it no one has ever gotten these 2 items and tryed to hook them up ... please help would be more then greatful
