JDM '95 H22 swap into a 97' base 5 spd Lude
im doing this swap next week and ive ordered the motor from HMO already and ive also ordered the timing belt conversion kit,Hondata IM gasket,cam seal,and rear main seal.Ive been reading some similar swap threads and gathering info here and there but is there anyone whos don this swap in a 5th gen that can tell me what else ill need to do?
Ive read i have to switch the distributer,intake manifold,Alternator,Power steering unit....and thats all i got.If anyone can add some info id appreciate it.I know ill run into some snags but im just trying to get as much info before hand as possible
ya i already have a p72 with hondata s200,sorry forgot to add that.Im doing the swap b/c my engine is dying.Leakdown results were 8%,22%,12%,7% respectfully in each cylinder.
oil pump, oil pan baffle, intermediate shaft, thermostat housing
https://honda-tech.com/zerothread?id=1190113
https://honda-tech.com/zerothread?id=1015106
Thanks for the replies, well it looks like ill have to use 4th gen vtec injectors and resistor box,but the jdm h22 im getting is a 95,will those injectors be the same as a 4th gen vtec lude?
yes. Just make sure you have the OBDIIA - OBDI conversion harness and a basemap then your good to go. Just make sure you atleast get a street tune soon after putting the ecu in. You wont be getting the greatest gas mileage/power with a basemap.
Ya i have the manual tensioner kit on the way.Ok so here is a list of all that ive gathered for the swap please let me know if there is Anything else i need.
From USDM H22 to JDM H22:
intake manifold(injectors included)
oil pump/baffle
external coil
balancer shaft and timing belt pulley
TDC and CKP sensors
knock sensor
oil pressure sensor
Wiring harness(obd2)
intermediate shaft
Ill also be adding/changing:
Manual tensioner conversion
timing belt
water pump
front main seal
rear main seal
cam seal
valve cover gasket set
spark plugs
oil pump/baffle
external coil
TDC and CKP sensors
knock sensor
oil pressure sensor
intermediate shaft
timing belt
water pump
front main seal
rear main seal
cam seal
spark plugs
what about the oil pump(tdc and ckp sensors),and dist?would those still need to be swapped if using the p72 or jdm p13?I, pretty sure the answer is no,but i just wanna verify.Thanks for your help 98vtec
