Problem installing a 94 gsr cluster in my 91 crx
So, I just finished soldering up all the wires that are used for the 94-99 gsr cluster swap into the 90-91 CRX. I used these as points of reference...
https://honda-tech.com/zerothre...01807
http://www.angelfire.com/dc/oregonimport/gsr.html
Now, The first time I turned the key to on, everything lit up like it should, CEL turned on, then off (cycling the ecu), fuel pump ran. EVERYTHING but the turn signals worked from what I could tell. I didnt test to see if the ebrake light would turn off or if the seatbelt light would turn off.
I cranked it over, and it ran for 1 second before dying, I checked my kill switches, and tried again. This time I didnt get any power to the gauges at all, so I checked my fuses. One of them was melted and another was blown. Both 10A fuses, one for the alternator solenoid and the other was the switched power to cluster fuse (14 I think). I put a new fuse in each spot, and tried again, this time it immediately blew the alternator solenoid fuse again. Is there some wires in those sites that are not correct? Do I just have a short across some of my wires? Any idea what I did wrong?
This is a revised list of wiring that I had to do from that first link because some things were on there wrong...
"1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
3)Black/Yellow-12v power
4)green/Orange-Check Engine
5)yellow/Red-Oil Light
6)Green/Red-E brake
7)Blue/Yellow-Door Light
8)Red-Dash-Dash Lights-(POWER-red/blk on 13p connector)
9)Red/Black-Dash Lights
10)Yellow/Green-Water Temp.
11) red/Blue-High beam
12) Green/Blue-Turn Signal Left
8 Pin connector:
1)Green/Yellow-Right Turn Signal
2)Yellow-12v Power
3)Yellow/white-Fuel Gauge
4)Blue/Red-Driver Seat Light
5)Green/black-Trunk light
6)Not used
7)yellow/red-Speed sensor
8)Black-Ground
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
2)Green/Orange-Check engine
3)Yellow/Orange-Oil Light
4)Not Used
5)White/blue-Volts
6)not used
7)Yellow/green-Water Temp.
8) black-ground
9) Red/Blue- cruise (not used unless you have it)
10) Yellow-12vPower
11) Not Used
12) Not Used
13) Not Used
16 Pin connecter
1)Green/red- E brake
2)red/Green-High Beam
3)Green/Yellow-Right Turn signal
4)Green/Blue Left turn signal
5)not Used
6)black/yellow-12vPower
7)Red/Black-Power
8)Red-12vpower
9)blue/Red-ABS(not used unless you have it)
10)green-Trunk Light
11)Orange-VSS
12)not used
13)Blue/White-Low Fuel(not used unless you have it)
14)Yellow/white-Fuel Gauge
15)Green/Red-door
16)red/blue-seat belt
TIA!!
"1990-91 CRX:
12 pin connector:
1) Blue-tach
2)White/Blue-Volts
6)Green/Red-E brake
8 Pin connector:
2)Yellow-12v Power
6)Not used
8)Black-Ground
94-01 GSR:
13 Pin connector:
1)Blue- Tachometer
4)Not Used
5)White/blue-Volts
6)not used
8) black-ground
10) Yellow-12vPower
11) Not Used
12) Not Used
13) Not Used
16 Pin connecter
5)not Used
7)Red/Black-Power
8)Red-12vpower
11)Orange-VSS
12)not used
15)Green/Red-door
TIA!!
blkrex
12
Jul 12, 2008 11:40 PM
ALLMOTOR CRX
Feb 1, 2007 02:01 PM
B16CRXT
20
Jun 2, 2006 08:43 AM
yeegsr
Jun 28, 2005 10:40 PM
