Sandblasting suspension pieces, whats a good paint when i'm done?
Old May 27, 2006 | 11:39 AM
miksew's Avatar
Default Sandblasting suspension pieces, whats a good paint when i'm done?
Thinking about sandblasting somne suspension pieces. Instead of powdercoating, what would be a good paint/coating to make them all shiny while also preventing rust?
Old May 28, 2006 | 06:49 AM
Qveon's Avatar
Default Re: Sandblasting suspension pieces, whats a good paint when i'm done? (miksew)
Well if you are going to blast, then prime, you can practically use any paint you would like. Krylon if your heart desires.
Old May 28, 2006 | 01:22 PM
snowseeker's Avatar
Default Re: Sandblasting suspension pieces, whats a good paint when i'm done? (Qveon)
POR-15
Old May 28, 2006 | 02:28 PM
Hawkze_2.3's Avatar
Default Re: Sandblasting suspension pieces, whats a good paint when i'm done? (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">POR-15</TD></TR></TABLE>
Hell yes! We use POR (Paint Over Rust)-15 where I work to prime large military equipment and it's the BEST primer on the market but it runs about $125/gallon.
Blast your peices clean, then allow a few days or so for a little rust build up and hit it with a couple thin coats of POR. Those things will last forever....
Old May 28, 2006 | 04:17 PM
confusatron's Avatar
Best bet is to have them powdercoated. For as cheap as it is to have done (at least where I am) is well worth it. Paint is cool and it looks nice for a while, but powdercoating lasts a lot longer. You have infinite options for colors as far as pearl, metallic, gloss, candy, textured, etc. My two cents.
Old May 28, 2006 | 09:25 PM
miksew's Avatar
Default Re: Sandblasting suspension pieces, whats a good paint when i'm done? (confusatron)
well its not a show car and these parts will most likely never see the light of day
so por-15 it is
Old May 30, 2006 | 02:07 AM
Raw B's Avatar
POR 15 is awesome. if you want to paint another colour over it, do so while the POR is still tacky, otherwise its gunna stay black/gray. Also, if you can find it, there is an awesome industrial paint called "Steel-It". It has a stainless steel pigment and is solvent resistant. We used to paint gearboxes at my old work with that stuff. About 30 bux a can (CDN)
skyviewLA01
Paint and Body
Feb 18, 2016 03:20 PM
WhiteOnRice
27
Mar 4, 2007 07:22 PM
97civic123
Jun 21, 2005 08:36 AM
posterchild
20
May 27, 2004 03:41 PM
972drcordex
May 25, 2004 08:45 PM
