Help with traction bar in CRX with BIG header.
Old May 27, 2006 | 11:15 AM
sircrxracer's Avatar
Default Help with traction bar in CRX with BIG header.
Ok I have a street CRX with "traction bars" and I have a DTR street sweeper header the big problem is my one radius rod is in the way big time can someone maybe give my some ideas on how to re-do the design so I can fit the header?
Here's some pics of the bars and header. TIA Rob
Old May 27, 2006 | 12:57 PM
HamiltonRex's Avatar
Default Re: Help with traction bar in CRX with BIG header. (sircrxracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sircrxracer &raquo;</TD></TR><TR><TD CLASS="quote"> my one radius rod is in the way big time </TD></TR></TABLE>
Where is it hitting exactly?
Does the piece need to be moved down more or over... Like does the header NEED to sit above or beside the traction bar piece?
If it needs to be moved down, you will have to build a new bar that sits lower in the front. Looks like you used a piece of angle to bolt it to where the factory holes are.
See if perhaps you could get some longer bolts, and take a piece of 1" rod with a hold in the middle to make it mount lower.. I would also add some plates that go up to the tow hooks so it dosent pull the bar back with the spacers (if it works.. Weld the spacers to the angle pieces)
Sorry if its hard to understand.. Kinda trying to describe what i see in my head.
Old May 27, 2006 | 03:47 PM
egrice's Avatar
take off the traction bar
Old May 28, 2006 | 09:46 AM
blueoval557's Avatar
Default Re: (egrice)
If the header needs to sit next to the traction bar, have a new radius rod made with a a bend in it so it clears the header. If you make it out of the right material, it wont weaken it at all.
GREAT looking header by the way! I really like that!
Kyle
EDIT: I realized that its nott he tubing thats in the way, but the heim joint and attachment point. Therefore, my idea wouldnt work, and I am not sure what you can do.
Old May 28, 2006 | 10:53 AM
shortyz21's Avatar
Default Re:
is it hitting the radius rod or near the heim joint?
you prolly gotta move the heim joint mount point over by a few inches, then shorten the radius rod to make it work...
but thats playing with suspension geometry u might wanna contact someone who knows what ill effects that might do to the suspension..
Old May 29, 2006 | 05:33 AM
Default Re: Re: (shortyz21)
It's the hiem joint and radius rod in the way the only thing I can come up with is the lower the mounting loctaion. Rob
Old May 29, 2006 | 07:54 AM
weiRtech's Avatar
OG Fabricator
make up some spacers to lower the bar rob. or you could have a new bar made that moves the whole bar further forward. mine sits directly in line with the tow hook locations on my crx.
Old May 29, 2006 | 09:09 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: (weiRtech)
hmm cut the ends off on the round bar rotate the bar down so the flanges are up and down weld it back up.
Old May 29, 2006 | 10:31 AM
RC000E's Avatar
Default Re: (ExplicitSpeed360)
Redesign the traction bar setup and use the rear crossmember for mounting. That's what I did on my old straight line car that had the same problem.
Old May 30, 2006 | 05:16 AM
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Redesign the traction bar setup and use the rear crossmember for mounting. That's what I did on my old straight line car that had the same problem. </TD></TR></TABLE>
Do you have any pics of that set-up?
Arron do you think you could help me out on this? Rob
Old May 31, 2006 | 05:11 AM
weiRtech's Avatar
OG Fabricator
yeah, i could probably figure something out for you rob. let me know what your schedule is like. i'm pretty busy right now but perhaps we could hook up one night after work since i'm working in cambridge now.
Old May 31, 2006 | 07:59 AM
Cool man, I doubt we could do this by this weekend but I have to race Sunday..... but I have to run this header, Rob
Aquafina
10
Jan 6, 2008 11:27 PM
g2_teg_
35
Nov 29, 2007 05:13 PM
bambam
Jun 24, 2006 10:44 AM
akhom
Oct 12, 2004 04:12 PM
blackntegra
Oct 15, 2003 07:28 AM
