92 Accord leaking oil
Old May 27, 2006 | 11:08 AM
Mualphapiper's Avatar
Default 92 Accord leaking oil
Hello folks,
My accord is leaking oil, I'd say about 3-6 drops a day on the pavement. I just replaced the valve cover gaskets which helped a little (there was some coming out from the falve cover and dripping down on the passenger side and that has stopped) but there apears to still be some leaking out the rear drivers side of the engine:
See bellow for leaky oil area:
Please tell me this isn't the head gasket! (Ok, you can if you think it is, but I won't be happy ) What's going on here?
The Piper
Old May 27, 2006 | 02:31 PM
knucklehead11's Avatar
Is the oil possibly coming out of your spark plug holes? If so, you probably need to get your cam tower O-rings replaced. This is just one possibility.
Old May 27, 2006 | 03:14 PM
immalooser's Avatar
Default Re: (knucklehead11)
hmm i'm actually leaking from there too. i have no idea where its coming from.
Old May 27, 2006 | 07:30 PM
Default Re: 92 Accord leaking oil (Mualphapiper)
Thanks, I replaced the O-rings around the spark plugs along with the valve cover gasket so that's not it (oil was pooling in there...not good for spark I'm sure!) and the holes around the spark plugs are clean after two weeks.
Old May 27, 2006 | 07:37 PM
BLKFLSH's Avatar
All I can think of, in that area, is the cam, balance shaft, and crankshaft seals under the timing covers. Or maybe the head gasket, but I doubt that. If oil is getting on your timing belt, it could be bad news. Try to clean the area off (degrease) so you can better tell where the oil is coming from. Good luck
Old May 28, 2006 | 04:07 PM
deserthonda's Avatar
Default Re: 92 Accord leaking oil (BLKFLSH)
it is leaking from the cam seal..........100% ,,,seen it many many times
unless you mis-installed the valve cover gasket and pinched the corner
contrary to what it was said ,, it is not the balancer shaft seal or crank seal ,
they are below that , inside lower t-belt cover ..
Old May 28, 2006 | 05:24 PM
H2290's Avatar
Default Re: 92 Accord leaking oil (deserthonda)
I agree with desert. Definitely the cam seal.
Old May 29, 2006 | 06:39 AM
immalooser's Avatar
so is there a proper way to seat the cam seal? I replaced mine not to long ago and it still leaks.
Old Jun 8, 2006 | 08:33 AM
So, in This parts list, is it #30? or # 5,6,7?
And will I need to remove the timing belt to replace this? Its about time to do my timing belt anyway.
Old Jun 8, 2006 | 05:06 PM
acc9ord3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immalooser &raquo;</TD></TR><TR><TD CLASS="quote">hmm i'm actually leaking from there too. i have no idea where its coming from.</TD></TR></TABLE> yeah i had the same problem for a bit. quite a scare till i figured out it was bad o-rings
Rocinante
May 24, 2015 07:49 PM
MacR6
Jan 2, 2014 09:35 PM
1997accordlx
Jan 7, 2010 12:32 PM
polodinks_gsr
15
Oct 5, 2007 07:38 PM
HondaMike17
Mar 16, 2006 03:20 AM
