what tranny oil in b16a2 box
Old May 27, 2006 | 07:16 AM
b16a2civicesi's Avatar
Default what tranny oil in b16a2 box
workshop manuel says 15/40 engine oil is this right?
Old May 27, 2006 | 07:19 AM
tatmark1's Avatar
honda manual tranny fluid
Old May 27, 2006 | 07:23 AM
akstunt600's Avatar
Default Re: (tatmark1)
WOW i feel bad for u. every honda owner should know this. all honda manuals take REGULAR MOTOR OIL 10w30 ONLY even the k h and the f20c
read and fsm or even chilton. the synchros do not like regular trans fluid and WILL most likely grind prematurely
Old May 27, 2006 | 07:24 AM
tatmark1's Avatar
Default Re: (akstunt600)
HONDA now recomends HONDA MANUAL TRANSMISSION FLUID
kids know everything...lol
Old May 27, 2006 | 07:31 AM
akstunt600's Avatar
honda has not canged anything get an fsm for the rsx i know what it says i have one. it says to use HONDA trans fluid OR regular 10w30 motor oil
Old May 27, 2006 | 07:36 AM
tatmark1's Avatar
so u changed from only useing regular motor oil to either?
Old May 27, 2006 | 07:43 AM
spoonracer84eg's Avatar
Honda MTF
akstunt600's Avatar
not really, i always use 10w30 and im a professional full time mechanic i work on many hondas a week
we also use 10w30 in our 8sec. hot rod race car
but i changed my wording to be 100% correct b/c honda always says honda lube/filter/gasket etc. before the mentioning the other product types that fit or work in their fsm
impoperformance.net
http://www.myspace.com/akstunt600
Old May 27, 2006 | 07:48 AM
philosofy1's Avatar
Default Re: what tranny oil in b16a2 box (b16a2civicesi)
honda mtf from the dealer! i have had no problems, works great
Old May 27, 2006 | 07:51 AM
Syndacate's Avatar
I use regular 10w30 motor oil -- mobile 1, not honda O.O
Maybe that's b/c that's all I use, it was like the best oil for my benz which I was driving awhile (15w50), so maybe it's jsut me, but I <3 that oil
Old May 27, 2006 | 08:19 AM
akstunt600's Avatar
oh yeah i forgot to say sythetic 10w30 works well if not better too
Old May 27, 2006 | 09:34 AM
tatmark1's Avatar
Old May 27, 2006 | 10:07 AM
akstunt600's Avatar
the reason behind not using regular gear oil is that honda synchros are designed to be used with a light/medium oil most gear oils such a 80/w90 are way to thick and will cause premature synchro failure
Old May 27, 2006 | 11:59 AM
Brick Top's Avatar
Honda MTF
Old May 27, 2006 | 12:15 PM
Junkie Si's Avatar
Default Re: (brick top)
i would use the honda MTF. Thats what honda recommends. I have used 10w30 in tranny's, but the regular oil just needs to be changed more often.
craze8
Feb 28, 2006 08:30 PM
daklown
11
Oct 15, 2003 11:09 AM
EK45VTi
30
Jun 5, 2003 05:49 PM
stealthteg
Jul 25, 2002 01:20 PM
Chairman Kaga
Jul 18, 2001 09:15 PM
