drop valve or piston ring
Old May 26, 2006 | 11:17 PM
JJ's civic's Avatar
Default drop valve or piston ring
i'm burning oil and i was wondering how can i found out if i drop a valve guide or blew a ring?
Old May 27, 2006 | 12:20 AM
SD_Lurker's Avatar
HT White Ops
Default Re: drop valve or piston ring (joeny12985)
ahhh??? Either one of these will cause a loss of compression. My guess would be to check your compression and see what cylinder is low and then go from there.
Old May 27, 2006 | 10:48 AM
JJ's civic's Avatar
Default Re: drop valve or piston ring (nicks_jdmstyle_ef9)
will i know of i pull the head off?
Old May 27, 2006 | 10:53 AM
slpnz6's Avatar
yah if its a valve you will real quick... cuz the piston will be shot ta **** and well you will be missing a valve.. haha... that does suck though... try checkin your plugs before you pull the head off.. might be a good indication of what going on ... you know if its damaged or something... but honestly you would know if you dropped a valve.... i would say its your rings... but every situation varies...
Old May 27, 2006 | 11:30 AM
akstunt600's Avatar
how bought a leak down test put the cylinder in question at tdc and turn the pressure up on leak down tester, listen form the tail pipe and the intake, if it is not holding presure u will hear air coming out of either end in/ex.
if ur putting 100 psi and less than 80 psi is holding, and u dont hear anything out the in/ex ur rings r shot.
Old May 27, 2006 | 02:28 PM
.Manny.'s Avatar
Touching My Member
Default Re: (akstunt600)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 &raquo;</TD></TR><TR><TD CLASS="quote">how bought a leak down test put the cylinder in question at tdc and turn the pressure up on leak down tester, listen form the tail pipe and the intake, if it is not holding presure u will hear air coming out of either end in/ex.
Remove your PCV valve and if you hear the air coming through there, bada bing bada boom, its the piston rings
Old May 27, 2006 | 09:55 PM
JJ's civic's Avatar
Default Re: (90_EF_Si)
I'll do that tomorrow i'll check the pcv valve
Old May 29, 2006 | 10:33 AM
JJ's civic's Avatar
Default Re: (joeny12985)
i pull the hose of the pvc and it ws sucking air in as i put my finger over it it pull it does it was coniste preusre?
Old May 29, 2006 | 10:40 AM
crx_88_si's Avatar
good lord.
do you know what a leak down test is? the engine is not supposed to be running you remove a spark plug, put a compressor in the plug hole and pressurize the cyl and listen for leaks at 1 of 4 places.
1. intake
2. exhaust
3. pcv valve or oil cap
4. coolant. (looking for bubbles in the fluid at the rad cap).
Old May 29, 2006 | 08:25 PM
JJ's civic's Avatar
Default Re: (crx_88_si)
i dont have a compressor.
nemesis25
Jan 12, 2015 04:17 PM
DCiFound
Sep 7, 2014 10:43 PM
Christopherian1982
Jan 13, 2009 12:09 AM
oilguzzler
Nov 22, 2005 05:26 PM
Yosshaa
May 23, 2004 11:55 AM
