Rear engine mount
Old May 26, 2006 | 10:20 PM
flight50's Avatar
Default Rear engine mount
I am needing to visit a local junkyard again. I need a rear mount bracket. What is the size of the bolt on the rear motor mount on the 90-93 accord. also what advise do you guys have to get that sucker off beside using muscle.
Old May 27, 2006 | 05:05 AM
Ross 2.0's Avatar
In a Junkyard near you.
it's either a 14mm or a 17mm but I would put more money on a 17mm. All you can really use in the boneyard is muscle so give it a shot
Old May 27, 2006 | 02:15 PM
raceACCORDingly's Avatar
17mm
i tried going from under w/ crowfeet wrenches and extension but it was a no go w/o taking out the axle and half shaft.
so i went from the top and took off the intake manifold since my EGR ports, IACV, FITV, etc.. needed cleaning and also threw in a Hondata heatshield intake manifold gasket in while i was at it to make it a little more worth while.
i know that the 4th gen and 5th gen 5spd LX mounts are all the same if that helps any.
mclasser
Aug 4, 2015 12:37 PM
98bucket
Mar 1, 2011 08:41 AM
TheOdd001
Feb 17, 2010 05:02 AM
Nathan007
Jul 7, 2008 03:20 PM
bloodgulch
Oct 21, 2007 04:31 PM
