Acura Legend Question
Well, I have an Acura Legend atm, and me and my friend was fighting about how to get the best mpg.
Its an automatic and on the pad it says D1.D2.3.4 he says 4 gives the best mpg but i dont beleive him, anyone here know the real answer with proof?
yes with an auto putting the car in D4 will allow the transmission to use all 4 of its available gears. One way of increasing gas mileage is look at the owners manual and look for a section about high speed driving (not all honda/acura manuals have this section). In this section it will tell you what the proper inflation value is for the tires if you are to be traveling over 100mph. Usually this value is 4 or so PSI higher than the normal inflation value. By "overinflating" your tires to this it will lower the rolling resistance of the tires slightly at the cost of some handling and braking degredation. Using this trick and driving like a little old lady will greatly improve your mpg.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">k, ty,
too clear my confusion, you do know its an automatic, right?</TD></TR></TABLE>
yes I do, Also you should replace your O2 sensors, fuel filter, and do a good tuneup once in a while for good gas milage. dont have a lead foot and the cruise contol is your best friend. you dont need to be passing everybody when you drive, just keep it nice and steady.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Desired_Speeds »</TD></TR><TR><TD CLASS="quote">yes I do, Also you should replace your O2 sensors, fuel filter, and do a good tuneup once in a while for good gas milage. dont have a lead foot and the cruise contol is your best friend. you dont need to be passing everybody when you drive, just keep it nice and steady.</TD></TR></TABLE>
those are definatly things that while they cost money to perform on your vehicle will add up at the pump
kekekekevin
Jul 24, 2006 12:17 AM
drsues02
May 24, 2002 12:52 PM
