*Searched* need wiring diagram for 2000 civic hx...remote start hook up
Planning on hooking up my remote start tomorrow, but need a wiring diagram of my car. I know there are endless threds on this subject, I've seen them and saved them, but my hard drive recently crashed, and I lost all my info. any links or info would help!
thanks
thanks
the manuel looks pretty crazy, I could figure it out Im sure...but has anyone done this? looking for some tips and hints. I know something about putting a switch on your shirfter so it will only start in nuetral, and also there is a way of hooking the remote start up without having to cut your clutch pedal switch
if you catch the starter wire after the clutch you dont need to cut anything, after the clutch means main harness after engine side of fire wall drivers side. As for as making it neutral start safe I think DEI makes a module that you can use that makes you do a sequence of steps before you get out of the car. I have a clifford avantguard 5 on my si and before I get out of the heres the steps I have to do.
1.stop
2. put car in neutral
3. put e brake on
4. push trunk button on remote(turns on safe start)
5. take keys out of ignition
6. get out of car
7. close door
8. arm alarm and car shuts off.
Its alot of steps but I know I dont have to worry about my car jumping into a wall or another car.
1.stop
3. put e brake on
6. get out of car
7. close door
I wouldn't mind taking 10 more steps, just as long as I knew my car wouldnt go any where when i hit that remote start button. Here's the problem, I just looked under my dash, not good... I had my alarm installed at some place by "professionals" and I look where the main unit is, and all I see is just a rats nest of wiring. EVEN if somehow i found the right wires from my alarm, there would b no way in hell I could find the right one for the car. I need to find someone thats done this install, that could walk me threw it, step by step...otherwise not be cool and not have remote start
anyone?
Im working with the autopage system, RS-855 LCD
anyone?
97civicsedan
May 3, 2007 10:55 PM
egcivicdelsol
33
Jul 16, 2006 06:38 PM
