96 civic Help!!!!!
wat up, i just did a z6 intake manifold swap on my d16y7. it went in pretty good and it was very easy. the only thing is that the car is idling at 4000rpms. need help. why is it doing that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdamian95 »</TD></TR><TR><TD CLASS="quote">You also may have a vacuum leak.</TD></TR></TABLE> i made sure everything was connected though where could i have the leak?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business »</TD></TR><TR><TD CLASS="quote">is your throttle body open? </TD></TR></TABLE> nope i checked for that and it was closed
Check all of your vacuum hoses. It could be anywhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdamian95 »</TD></TR><TR><TD CLASS="quote">You also may have a vacuum leak.</TD></TR></TABLE>i pluged the iacv in the z6 manifold with the sensors itself without connecting it, u think that would be it?
bump for an answer...my buddy did the same thing on his cx hatch. Always had a high idle before it was warmed up. Never found out what it was, we checked all his vacuum lines too, didn't have a leak either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdamian95 »</TD></TR><TR><TD CLASS="quote">check the wires from the IAC. See if the is voltage.</TD></TR></TABLE> how do i do that man?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdamian95 »</TD></TR><TR><TD CLASS="quote">Discoonect the plug for the iac and you will need a volt meter. Turn car on and see if there is 5volts. If there is voltage your wires are good.</TD></TR></TABLE> I have voltave so the wires are good right?
wat the hell could it be?
vaccum leak - make sure you cleaned off all the old gasket material.
throttle cable too tight
adjust idle screw
IACV fix/rewire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by el negro »</TD></TR><TR><TD CLASS="quote">wat up, i just did a z6 intake manifold swap on my d16y7. it went in pretty good and it was very easy. the only thing is that the car is idling at 4000rpms. need help. why is it doing that?</TD></TR></TABLE>
adjust idle screw
IACV fix/rewire?
i almost know what it is, your stock intake manifod on the y7 was a down draft pile and you upgraded, and your ecu isn't recognizing the increased airlfow so its idleing high. mine did the same thing only i put a throttle body spacer on. good luck man!
Y7 and Z6 throttle body is the same diameter. How will a throttle body spacer affect idle?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeekekciv »</TD></TR><TR><TD CLASS="quote">i almost know what it is, your stock intake manifod on the y7 was a down draft pile and you upgraded, and your ecu isn't recognizing the increased airlfow so its idleing high. mine did the same thing only i put a throttle body spacer on. good luck man!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock »</TD></TR><TR><TD CLASS="quote">vaccum leak - make sure you cleaned off all the old gasket material.
adjust idle screw
IACV fix/rewire?
</TD></TR></TABLE>Thanks man. The old gastket was hard to get off but i got all of it off. Im going to check everything else.
adjust idle screw
IACV fix/rewire?
