power window q
Old May 26, 2006 | 02:22 PM
egg_baLLa's Avatar
Default power window q
i already searched. i dont know if it's just me, but i do not for the life of me understand the instructions on repo.jackmoves.com
i have a 93si and was wondering if my car is already pre-wired for power windows? although i did buy the ex harness. i already installed everything except for the wiring and i don't know how to wire it up to the underdash fuse box?
Old May 29, 2006 | 06:31 PM
egg_baLLa's Avatar
Default Re: power window q (egg_baLLa)
ok so a few more hours of studying schematics and diagrams i finally understood a little bit more.
if u go here and take a look at the pic of the green plug on the right, can someone tell me wat color wires connect to each pinhole from the driver door harness?
i have a helms manual, but i cannot find it in there? if someone can direct me to the page, that would be even better.
http://repo.jackmoves.com/v/er...1c9ef
Old May 29, 2006 | 07:52 PM
egg_baLLa's Avatar
anyone?
Old May 29, 2006 | 10:16 PM
melsers's Avatar
You have the harnesses? It should just be plug n play. No worries about wire colors.
Old May 30, 2006 | 12:13 AM
CivicSiRX's Avatar
check out he diagram i made in this thread.
https://honda-tech.com/zerothread/1640659
Old May 30, 2006 | 01:13 AM
egg_baLLa's Avatar
Default Re: power window q (CivicSiRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by melsers &raquo;</TD></TR><TR><TD CLASS="quote">You have the harnesses? It should just be plug n play. No worries about wire colors. </TD></TR></TABLE>
the thing is, the driver door harness does not have the green plug attached to it. i have an si, so i DO have the green plug. all of the wires for the door harness are cut off, so i need to know the exact colors for the green plug.
Old May 30, 2006 | 04:34 PM
egg_baLLa's Avatar
ttt
Old Jun 1, 2006 | 02:52 PM
egg_baLLa's Avatar
does anyone know where i can find the pins so that im able to put the wires into the plugs?
import-tooner
Aug 25, 2010 10:12 AM
Arthas
Oct 28, 2009 07:02 PM
TylerB
11
Jul 30, 2009 10:20 PM
Dr. Willy
Jan 12, 2008 11:22 PM
scottybh
Mar 12, 2006 07:29 PM
