Honda S2000 Honda S2000
slotted vs. drilled?
Old May 26, 2006 | 12:50 PM
mykcuz's Avatar
Default slotted vs. drilled?
whats the difference between drilled or slotted rotors?
Old May 26, 2006 | 12:52 PM
WowOzYouRock's Avatar
Default Re: slotted vs. drilled? (mykcuz)
drilled are drilled and slotted are slotted .. hopefully i asnwer your question
Old May 26, 2006 | 01:04 PM
Mr. Projekt's Avatar
* B A N N E D *
Drilled has holes, and slotted has slots.
Old May 26, 2006 | 01:13 PM
p nut's Avatar
They do share something in common, however--zero performance gains and increased ghey-ness.
Old May 26, 2006 | 01:56 PM
- BSeRiouS -'s Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">They do share something in common, however--zero performance gains and increased ghey-ness.</TD></TR></TABLE>
hahah!
they are functional though in this case.
Old May 26, 2006 | 02:23 PM
S2KJ55's Avatar
they ummmm make it look like ur cars super fast....i think u get a real tru hp gain i dont know....
Old May 26, 2006 | 08:54 PM
specbb6's Avatar
Default Re: (S2KJ55)
they both suck.
Old May 26, 2006 | 10:03 PM
mykcuz's Avatar
Default Re: (specbb6)
so according to our h-t experts there is absolutely no difference between the two rotors?...ok well what atleast is the concept behind the two different rotors? i know theres no hp gain, and that in some cases it reduces whp because of the increased rolling mass, but in otherwords if one were to choose between the two u just want to pick the one that looks better?
Old May 26, 2006 | 10:09 PM
* B A N N E D *
Default Re: (mykcuz)
If you were so detailed in your first post...
Drilled: Make sure the holes are cast, not actually drilled. Pre-cast holes prevent cracking.
Slotted: Limits the amount of times you can resurface the rotors. After that they're just blank rotors.
Drilling/slotting reduces overall mass of the rotor, therefore reducing its effectiveness to withstand heat, unless being continuously cooled, which it does at an improved rate compared to stock.
Old May 26, 2006 | 10:13 PM
mykcuz's Avatar
Default Re: (FR-MOB: Projekt)
well thank you, but is there a performance reason to take one over the other design, or is it just"pick your poisen?"
Old May 26, 2006 | 10:17 PM
* B A N N E D *
Pick your poison.
Old May 27, 2006 | 12:57 AM
evil vapor's Avatar
There are a lot of opinions on how slots and drilled rotors perform in braking situations. If you drive your car hard at the track making up time by braking as late as possible, avoid drilled rotors even if they are casted into the rotor. You'll start to see small cracks/fissures around the holes even on a casted rotor.
Directionally veined rotors improve cooling efficiency and are worth the extra bucks, even on a blank rotor. If you dig the look, get both drilled and slotted otherwise save your money.
meangreenEG
22
Jul 28, 2007 12:31 AM
mrdeadman
Sep 27, 2005 08:14 PM
tekstyle
Oct 30, 2003 07:26 PM
ramz7887
Apr 24, 2003 06:45 AM
Rah Rah
Nov 22, 2001 05:43 PM
