how much fucking torque does it take...
Old Apr 13, 2002 | 01:53 PM
FusionITR's Avatar
Default how much ******* torque does it take...
im try to take off the bolt on the header that connects to the cat...
my air wrench is rated at 60 ft/lb's of torque and i still cant get it off!! How the hell do u take that thing off??? =/
Old Apr 13, 2002 | 01:55 PM
Jason's Avatar
Default Re: how much ******* torque does it take... (FusionITR)
let it soak in some WD-40 for a few hours...helps A LOT!
Old Apr 13, 2002 | 01:56 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
WD-40 or get another loosener agent, it helps. I got mine off with my own elbow grease. just keep trying at it. This is the bolt with the spring right?
Old Apr 13, 2002 | 01:59 PM
FusionITR's Avatar
Default Re: how much ******* torque does it take... (Rguy)
yeah, bolt with the springs
so wd40? i just sprayed some on right now, i pretty much soaked it.... how long should i let it sit?
Old Apr 13, 2002 | 02:08 PM
csufweed's Avatar
yeah mine came off with just a wrench and muscles...
you should just spray wd40 on let it sit for a few seconds and it should be good.
Old Apr 13, 2002 | 02:27 PM
mercury's Avatar
New User
This really shouldn't take that much effort, but a 1/2" drive with a 8' breaker bar usually works wonders 8'*100lb = 800lb*ft torque. If that bolt doesn't doesn't break loose, SOMETHING's gonna break loose.
Old Apr 13, 2002 | 02:28 PM
Dr Pooface's Avatar
Default Re: how much ******* torque does it take... (mercury)
Torch
Old Apr 13, 2002 | 02:33 PM
Isaac's Avatar
New User
Default Re: how much ******* torque does it take... (Ddub)
Those bolts are BITCHES!!! When I installed my JDM Header I had to have my neighbor come over with a powered saw and cut that bolt loose. But like everyone else said, use a good lube spray, (Liquid Wrench, PB, WD-40) and then use a breaker bar and bust it. Good Luck!
Old Apr 13, 2002 | 02:52 PM
Toda Party's Avatar
Default Re: how much ******* torque does it take... (Waxing "The Carrot")
i have more trouble w/ the cat to b-pipe flange bolts than the header to cat bolts
Old Apr 13, 2002 | 03:03 PM
SIINSI's Avatar
Default Re: how much ******* torque does it take... (Toda Party)
Yep, I'd do a combo of the WD-40 and the torch. Just be careful.
Miguel
Old Apr 13, 2002 | 03:09 PM
Jason's Avatar
Default Re: how much ******* torque does it take... (SIINSI)
Miguel
hehe, I don't know if I'd do that...WD is highly flammable
Old Apr 13, 2002 | 03:22 PM
onyx00's Avatar
Default Re: how much ******* torque does it take... (Jason)
Man, I hated those bolts with a passion.
Suggestion: If you plan on ever needing to mess with these bolts more than once a year, I would replace them with some new ones. I went to a local place that carries all kinds of nuts and bolts and now it is much easier to work with.
TypeRmsm has the exact specs of the bolts and washers you should use to replace the stock bolts.
Old Apr 13, 2002 | 03:42 PM
LSR 97's Avatar
Default Re: how much ******* torque does it take... (onyx00)
Use the Wizzy Wheel..... then goto Home Depot for new bolts....
LSR
Old Apr 13, 2002 | 04:09 PM
Zeus's Avatar
...and after you get it loose, use some antisieze from your local nut and bolt shop on all of the threads in the exhaust system...
Zeus- who's been know to pull the exhaust off a brand new car and use antisieze just to avoid such problems in the future...
ray.riddler92
Jul 27, 2011 05:07 PM
GSaura
Nov 30, 2006 07:16 PM
BlueShadow
10
Aug 1, 2004 02:11 AM
shermanyang
Jul 29, 2002 08:38 AM
jonsteR
Aug 10, 2001 08:55 AM
