breather hose from valve cover to intake tube? smog issue
im tyring to get my car smogged and i have the stock intake box and tube, but i dont have the hose that goes from the valve cover to the intake tube. I was wondering if i could just get a hose from autozone, or, do i have to go to honda to get the proper breather tube?
what i mean is that by looking at this link: http://www.hondaautomotivepart...AMBER
it looks like there is a different type of breather hose that needs to be hooked up, and not just a hose from the valve cover to the intake tube.
hope someone can help, just not sure which i need to get
mainly #7 and #8... just wanted to make i could just hook up a hose to connect the intake tube and valve cover
You can use any hose to replace #8. The #7 is just a piece of hardline. The top line is for the breather, coolant flows through the bottom line. You can leave the top line disconnected and just run a hose from the valve cover to the intake pipe.
