T3/T4 oil line interchange with GT28RS?
I bought turbo lines for for a T3/T4 because that is what I originally was planning on using. But after some research, I see that the Disco Potato (GT28RS) would be a much better turbo for my setup (around 400 HP). So I am wondering if the T3/T4 oil lines will interchange with the Disco Potato? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">I bought turbo lines for for a T3/T4 because that is what I originally was planning on using. But after some research, I see that the Disco Potato (GT28RS) would be a much better turbo for my setup (around 400 HP). So I am wondering if the T3/T4 oil lines will interchange with the Disco Potato? Thanks.</TD></TR></TABLE>
Anyone know?
Anyone know?
You'll need the oil feed adapter kit for the feedline, and you'll need the Coolant banjo fitting and lines to run the turbo. and though the drain size is the same threading and pitch, you may want to use a -8AN return line as opposed to the -10AN line that is typically used on the Journal Bearing designs. You'll also need to change to a GT25/28/3076 return flange and gasket, for they are NOT the same at all.
Hope that helps a bit.
sleepencivic
Jun 6, 2008 06:55 PM
