Accord belt replacement
Old May 26, 2006 | 05:01 AM
Honda_Camaro Owner's Avatar
Default Accord belt replacement
I have a 90 DX accord (so no A/C). Ive been searching on here for 15 minutes trying to find out how to replace these two belts. Is it as easy as unbolting one pulley from each and just taking it off or is there a tensioner that swings? Any help?
Thanks
Old May 26, 2006 | 05:12 AM
Ross 2.0's Avatar
In a Junkyard near you.
You adjust the p/s belt at the pump and the same goes with the alternator belt. It's a pretty easy job without a/c. Good luck
Old May 26, 2006 | 05:33 AM
Default Re: (MooGoCow3)
ok, what do you mean adjust it? I never work on this car, im always working on my camaro LOL
Forgive me for my ignorance. What pump are you talkin about and where is it located? I feel retarded asking for this much help on this car... HAHA
Do you not just unbolt one of the pulleys then?
Old May 26, 2006 | 05:53 AM
Ross 2.0's Avatar
Oh so the car probably doesn't have power steering either. Nice. I would love to to the timing belt on it
It's hard to explain how to loosen the adjuster. It's similar to most other alternators. Probably even to your camaro (if it's an older one).
The best way I can come up with is to looses the two bolts that fasten it to the block and then there will be a smaller bolt (probably a 10MM that will release the tension on the alternator.
Old May 26, 2006 | 07:06 AM
no, it has power steering. This isnt the timing belt tho (that has already been changed out). Im just talking about the two belts on the side of the block. They are starting to squeak and look worn.
I gotta look at this closer, or maybe i am just totally missing what you are saying.
Old May 26, 2006 | 12:09 PM
Default Re: (Honda_Camaro Owner)
Anybody? Im tryin to keep this car running good since Im trying to sell it.
Old May 26, 2006 | 01:35 PM
ricebike's Avatar
local library doesn't have a haynes/chilton manual for this vintage yet?
also, if you don't want to mozy on down to the local library...
AUTOZONE has some chilton/haynes manuals online fo free!
choose your vehicle year/make/model... then click on repair guides link on that paragraph... routine maintenance...belts & there u have it!\
no need for Helms on this one...
Old May 26, 2006 | 06:35 PM
Default Re: (ricebike)
wow... that is actually a really good tool, never knew autozone had that.
wish they had more diagrams, but beggars cant be choosers. Helped out a bit. What a **** poor design for adjusting tension... a belt on my camaro took more time to jack up the car than it did to change it. Figures only an import would have a design this bad...
Jason777
Jul 7, 2014 02:06 PM
famfive
Jul 25, 2010 08:29 AM
91ex
Oct 7, 2008 11:06 AM
houzful
May 1, 2008 07:08 PM
ddobos
Apr 17, 2008 09:33 AM
