how does Vtec work in simple terms?
Old May 26, 2006 | 01:16 AM
Electron_Blue_Kid's Avatar
Default how does Vtec work in simple terms?
everyone i ask gives me this big long explanation where it just seems like they are makin up wut their saying so you guys be the pros and let me know thx?
Old May 26, 2006 | 01:29 AM
skip.two's Avatar
Default Re: how does Vtec work in simple terms? (Electron_Blue_Kid)
http://auto.howstuffworks.com/question229.htm
simple enough? use the <u><FONT COLOR="red">Search</FONT></u> function next time.
Old May 26, 2006 | 01:30 AM
JDMlyfestyle's Avatar
Engine Reaches a Certain RPM.. then your ECU will check for the following
OIl pressure - Must be at least 55psi
Water Temp- must be at least 140 degrees F
Speed- Must be going 10 mph
And once that certain RPM Hits. The Vtec solenoid activates and Oil pressure pushes a Pin to Lock the Rocker Arms together and it activates the High Cam lobe.
rumo1112
Jan 17, 2011 10:57 AM
seldon
May 30, 2009 05:24 PM
502em1
13
Apr 18, 2007 10:53 AM
s1ngle
May 6, 2005 06:50 PM
Formula 1
May 23, 2003 03:30 PM
