does lowering your gear ratio show up on the dyno?
Old Apr 13, 2002 | 01:01 PM
jond's Avatar
Default does lowering your gear ratio show up on the dyno?
Old Apr 13, 2002 | 02:11 PM
nfn15037's Avatar
Default Re: does lowering your gear ratio show up on the dyno? (jond)
No
Old Apr 13, 2002 | 02:33 PM
Rboosted717's Avatar
yes it will. It will show up in the speed reading for the run as well as also give you more or less power pending the newness of the dyno software and setup. Most new dyno's will auto adjust for a 1to1 gear ratio where as other dyno's will just use the ratio for the gear that you run in.
Its best to contact your local dynoshop and ask them or find out their dyno model and giving the dyno manufactor a call and getting info since many people arn't aware of the dynoshops software and/or setup.
Old Apr 17, 2002 | 07:25 PM
jond's Avatar
Default Re: does lowering your gear ratio show up on the dyno? (Rboosted717)
be regardless of the software they're running, if your in 3rd gear with a stock 4.4 final gear, vs 3rd gear with a lower 4.75 final gear, shouldn't the lower final gear show more power?
Old Apr 17, 2002 | 07:28 PM
Reid's Avatar
Global Moderator
Assuming there's no correction made to compensate for the increased final drive, yes the dyno would show a gain in power.
Dr Pooface's Avatar
Why should it? A dyno measures power to rpm's. The shorter gear doesn't make your engine any more power, it just makes the rpms go by quicker.
Old Apr 17, 2002 | 10:12 PM
Black R's Avatar
25 Year Member
FYI:
I've done pulls on a local dynojet in 3rd and 4th gear both before and after installing my ats 4.929 final... The runs were within 1-2whp of each other... 3rd gear pulls usually net a little less for some reason. SAE numbers are very close.....
Old Apr 18, 2002 | 06:53 AM
Ideal R's Avatar
New User
No, as you need to enter your gear ratio into the dyno machine before you run.
Old Apr 18, 2002 | 09:17 AM
DutchITR1689's Avatar
Default Re: does lowering your gear ratio show up on the dyno? (Ideal R)
Most of them don't need that. It knows the drum rpm and the engine rpm (by ignition noise) so the final reduction can be calculated!!!
VTIargentina
Oct 23, 2009 10:43 AM
patdemps
Sep 19, 2003 01:56 PM
B16b2b
17
Jul 22, 2003 10:56 AM
4doorH22
Sep 7, 2001 10:24 AM
