"nutserts" always great to have.
From: hittin corners so hard you can taste my rims..
as some of you guys know.. the upper controll arms on EF's and EG's.. use a bolt through the controll arm, and have a nut tack welded behind the body and that bolts the inner arm.
well, a few of us have broke those tack welds loose.. and in my case, i couldn't loosen all the way out, or tighten it up.. i ended up tourching the bolt off.
well.. i'll introduce a "nutsert".
more pics avail in my listing here..
http://builtb16a.com/random/nutserts
a wonderfull tool to have!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hostiletx »</TD></TR><TR><TD CLASS="quote">I wouldn't use it on any type of suspension.</TD></TR></TABLE>
Was going to say the same thing
Good product, just not ment to hold load though
i used them on my CRX's uper controll arm.. i tourched the bolt off, and let the other half fall in.. put the nutsert in place, and used the OEM bottom bolt. so it was 50% on the nutsert.. and i didn't have a problem for 2 years.. now the car is apart being restored to JDM specs. bronze glass and all.
joshmak
11
Apr 21, 2010 11:52 AM
