Trying to hook up AC with my swap, will d series stuff work?
I was told i can use 2 bolts to mount my ac compressor, but which bracket do i need? I know i need the p54 from the del sol vtec, but i dont have 130 bucks to go to the dealership so i want to use either a stock b16a2 or a stock d16 bracket.
I was under the impression that i use the d16 bracket, and only the top and bottom bolts on the right side will line up. is this true, or is it the b series bracket i use.
I was also told you can use the one from a crv, pr7, p7r something like that. I ordered mine and it should only be in the 60-70 range, i just have to go get it. Then you can use your d-series compressor and you'll be good to go.
MShonda
Nov 22, 2010 07:20 PM
powderb18b
10
Jun 21, 2007 07:03 AM
slowpokesi
17
Jul 20, 2002 08:31 AM
