The Situation
Old May 25, 2006 | 06:59 PM
93(Civic)EG6's Avatar
Default The End of b16a Swap Situation
The Project: Ok I have completed my automatic JDM b16a swap into my automatic 93 Civic Ex Coupe.
The Problem: The car won't start and will only crank. Fuel is not being sent to the fuel regulator. Also don't think I am getting spark.
The Possible Reasons: Fuel pump is bad, Fuel filter could be clogged, ECU is bad, Fuel relay is bad, My Engine grounds I made aren't grounding it out.
I will get you some pictures tomorrow. To show you how it looks and maybe I didn't do something right.
If you are in the CT/Mass Area please let me know and maybe you can swing by and take a look!!
Any Ideas????
Modified by 93(Civic)EG6 at 8:10 PM 5/25/2006
Old May 25, 2006 | 07:14 PM
nota-eg's Avatar
Default Re: The End of b16a Swap Situation (93(Civic)EG6)
I'd reccomend testing the fuel pump first. Run a wire from the battery directly to the fuel pump. If it does not you may have a wiring problem.
Recheck all of your grounds.
I don't have an auto, but they do have some kind of gear selector safety switch, correct? If so did you hook that up?
Make sure everything is wired correctly.
Swap the ECU you have in the car now with another (ie: Old P28 or whatever it is the 93 autos run.)
Old May 25, 2006 | 08:38 PM
Sandmaggot's Avatar
Default Re: The End of b16a Swap Situation (nota-eg)
Get a M/T
Cameron60
Jan 16, 2007 06:04 PM
B18 CYA
Jul 5, 2006 07:46 PM
Ruben19
Jan 9, 2006 06:21 AM
Ruben19
Jan 8, 2006 09:38 PM
