suspension suggestions for street / occasional dragstrip
hey ive got a 94 ex coupe, with h&r race springs and kyb agx's. i think i could use some more suspension mods. i just wanna be able to take tight corners on the street, dont plan to do any road racing. any bang for buck suggestions is appreciated.
a front or rear sway bar, or both would increase handling quite a bit. also a subframe brace in the back if you do get a rear bar.
Yea... so you can get camber kits to dial in a bit more camber, but you'll sacrafice your tire's life for better handling, pretty much. you can also get new wheels/tires if you haven't already. A COMPLETE suspension system utilizes a good set of wheels/rubber. Remember, you have 4 contact points not even as large as a pieces of paper on the road, controlling a moving mass of 2300 lbs or so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">a front or rear sway bar, or both would increase handling quite a bit. also a subframe brace in the back if you do get a rear bar. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skcivic »</TD></TR><TR><TD CLASS="quote">Yea... so you can get camber kits to dial in a bit more camber, but you'll sacrafice your tire's life for better handling, pretty much. you can also get new wheels/tires if you haven't already. A COMPLETE suspension system utilizes a good set of wheels/rubber. Remember, you have 4 contact points not even as large as a pieces of paper on the road, controlling a moving mass of 2300 lbs or so.</TD></TR></TABLE>
for the dragstrip, I have no idea at all why you want to upgrade your sway bar.
or mess with more camber.
If you want faster drag, upgrade motor mounts, short shifter, clutch/flywheel, lighter everything. And practice launching/ET/60ft.
murderedrsx
14
Feb 22, 2010 12:11 PM
civic_tko
10
Nov 4, 2004 02:29 PM
