help! my ecu wont come on
Old May 25, 2006 | 12:53 PM
95vr6man's Avatar
Default help! my ecu wont come on
i have an 89 civic hatch with a d16y8 motor and all running obd1. i have a harness built by rywire so i know that its good. the ecu will not come on, no check light when the key is on, no spark, no fuel(by "no fuel", i mean no injector pulse). the main relay is also working properly, it turnes on the fuel pump and it runs for 2 seconds as well as the injectors have power for 2 seconds(the obd0 main relay works differntly than the obd1+ where the injectors always have power, they only have power when the ecu sees rotating.. engine starting.. running.. ect.) i have tried a p28 ecu and a p06 ecu and both of them should be good ecu's so i know thats not the problem. i have checked the following pins for power at the ECU and all the proper grounds as follows:
OBD1
A1-INJ1 INJ1 Brown, Battery Voltage with KOEO on for 2 seconds
A2-INJ4 INJ4 Yellow, Battery Voltage with KOEO on for 2 seconds
A3-INJ2 INJ2 Red, Battery Voltage with KOEO on for 2 seconds
A4-VTS VTEC solenoid GRN/YEL, N/a
A5-INJ3 INJ3 Blue, Battery Voltage with KOEO on for 2 seconds
A6-PO2SHTC O2 sensor (heating element) Org/Wht, Battery Voltage with KOEO
A7-FLR1 fuel pump Grn/BLK, Battery Voltage with KOEO on for 2 seconds
A8-empty A7 and A8 have the same circurt, so they can be the same
A9-IACV IAC valve Blk/Blu, About 10v KOEO on Warm engine
A10-empty
A11- This is EGR Control Solenoid Valve (if the ECU has) Red, N/A
A12-FANC engine coolant temp switch Blu/red, N/A
A13-MIL MIL (check engine light) Blu/wht, N/A
A14-empty
A15-ACC (a/c compressor clutch) Red/Blu, N/A
A16-ALT C alternator Wht/Grn, N/A
A17-IAB IAB Solenoid Pink, N/A
A18- Org/Red, Transmission Control Module (A/T), N/A
A19- White, Intake control solenoid, Battery Voltage with KOEO
A20-PCS EVAP purge control solenoid Red/Grn, N/a
A21-ICM ICM Yel/Grn, Ignition Control Module (ICM) Output signal, About 10V KOEO i dont think ive checked this one, i will when i get home
A22- *per Sander* Ignitor same as A21
A23-PG1 ground Black, Power ground, less than 1V good ground
A24-PG2 ground same as A23 good ground
A25-IGP2 to main relay and to gound for o Yel/blk, Battery positive from Main relay, Battery Voltage with KOEO good power with KOEO
A26-LG1 gound Blk/red, less than 1V good ground
B1-IGP2 to pin A25 Yel/Blk, Battery positive from Main relay, Battery Voltage with KOEO 12v power with KOEO
B2-LG2 ground to shields for CYP & TDC Brown/Blk, Less than 1V good ground
B3- Orange, upshift/downshift comparative input, N/A
B4- Pink, upshift/downshift comparative input, N/A
B5-ACS a/c switch Blu/Blk, A/c input, About 5V with KOEO & A/C off; less than 1V KOER with A/C & blower on
B6-empty
B7- Light green, Park/Neutral switch (A/T), Less than 1V in Park or Neutral with KOEO; 5V in Park or neutral with KOER; Battery voltage in all other positions
B8-PSPSW PSP switch Red/Green, Power steering oil pressure switch, 0V KOEO; Battery Voltage KOER While slowly turning steering wheel
B9-STARTER SIGNAL starter signal Blue/red, Battery Voltage in the START position (clutch depressed on M/T models) havent checked this one but im sure its good since the starter turns
B10-VSS vehicle speed sensor Orange, Pulses 0-12V while turning the left front wheel
B11-CYP P CYP -P Orange, CYP sensor input, N/A
B12-CYP M CYP -M White, CYP sensor signal, N/A
B13-TDC P TDC -P Org/Blue, TDC sensor input, N/A
B14-TDC M TDC -M Wht/Blue, TDC sensor signal, N/A
B15-CKP P CKP -P Blu/Green, CKP Sensor input, N/A
B16-CKP M CKP -M Blu/yel, CKP Sensor signal, N/A
D1-VBU Back Up Power Wht/Yel, Battery positive From battery through Fuse Box, Battery Voltage at ALL times has 12v at all times
D2-BKSW brake switch Grn/wht, Battery voltage at all times
D3-KS Knock Sensor Red/Blue, N/A
D4-SCS service check connector Brown/Wht, About 5V (M/T); About 11V (A/T)
D5-empty
D6-VTM VTEC pressure switch Light Blue, N/A
D7-TXD/RXD (data link connector) Light Green/Red, N/A
D8-empty
D9-ALT F alternator Wht/Red, Alternator Charging Signal, About 4.5V KOEO; Decreases under Electrical load (Headlights & rear defogger on) At warm idle havent checked this one, will check it when i get home and update
D10-ELD electric load detector input Grn/Blk, N/A
D11-TPS TPS Signal Red/Blk, About 0.5V KOEO with throttle fully closed; About 4.5V KOEO with throttle fully open
D12- Wht/Blk, EGR Valve Lift sensor, About 1.2V KOEO
D13-ECT ECT sensor input Yel/Blu, About 5V KOEO (varies with temperature)
D14-PHO2S O2 sensor White, heated 02 sensor Signal, 0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes
D15-IAT IAT sensor Red/Yel, Intake Air Temperature signal, .05-4.5V KOEO(Varies with temperature)
D16-VREF VREF shows BLANK on my diagram
D17-MAP Map Signal Wht/Blu, About 3V KOEO (Varies with Temperature)
D18- Light Green/Blk, Transmission Control Module (A/T Only), N/A
D19 - Red/Wht, Reference Voltage, About 5V KOEO 4.95V exactly
D20 - Yel/Wht, Reference Voltage, About 5V KOEO 4.95V exactly
D21 - Blue/Wht, Sensor ground, Less than 1V good ground
D22 - Green/Wht, Sensor ground, Less than 1V good ground
ok so what else do i need to check? any ideas or suggestions would be very helpful. thanks!
Details list:
88 civic STD
p28 manual ECU
rywire conversion harness for d16y8 and obd1
d16y8 running the obd2 dist
camtoe420
16
Jun 17, 2013 09:11 AM
95_red_dc
Jan 6, 2008 11:46 AM
krazyhmongboi
Feb 21, 2007 06:55 PM
95vr6man
May 27, 2006 06:48 PM
TBoDelSol
Nov 20, 2005 01:47 PM
