Oily/Sooty shit around the engine code?
Old May 25, 2006 | 09:38 AM
DC5ftmfw's Avatar
Default Oily/Sooty **** around the engine code?
My b16 has been a really clean engine but I've noticed that if I get on it really hard, I start getting that sooty **** building up above the engine code between the head and block....is it just that my headbolts aren't tight enough and it's lifting a tiny bit or what? When I boost, Im changing the headgasket and switching to ARP studs...should it stop?
Old May 25, 2006 | 02:08 PM
devnull's Avatar
Quite normal.
You could re-torque the head but you'll need to make sure that the head gasket is good before you re-use it, which some people say to never re-use a headgasket.
Old May 26, 2006 | 01:27 AM
Takumi Fujiwara's Avatar
Default Re: (devnull)
could be coming down from your dizzy or vtec solenoid as well... if you haven't already checked.
Grrobertg
Jul 29, 2017 10:09 PM
spoolinvtec54
May 9, 2011 03:18 PM
jitterbox2
Jul 2, 2006 12:03 PM
White V6
Oct 30, 2005 06:10 PM
kevo2k6
May 20, 2004 07:35 PM
