Toda A dyno charts?
i was searching for any Toda A charts but cuoldn't find any since the search is fugged up. if anyone can post up a chart of a stock ITR vs. Toda A or give me any comments on their set up. it would be appreciated, thanks.
I'm guessing red is spec C
Green is Spec B and
Blue is Spec A???
All Spec A's I believe it was just different runs after tuning.
Green is Spec B and
Blue is Spec A???
I've seen people who can't make 207whp with spec c's and tuning
In A LOT of cases I have seen SpecA cams make better power than the SpecB cams. I have made 196 Hp and 130 lbs-ft with my SpecA cams. They really are a GREAT street cam. Even more so than a CTR/ITR.
Don't get me wrong SpecB and SpecC cams are great too. You just have to have the right combo/compression. You can't just slap them in and expect 200 Hp easy. They like compression and lots of tuning.
-kenji
-kenji
I have posted several dyno charts of spec A's on my ITR. I made 178whp and 126 torque. This was with bolt ons and a VAFC. I ran out of fuel, but there was more power to be had.
The Spec A's made anywhere from 10-15+ torque over my stock cams from 5-7000rpm's and about 5 peak whp. They are a good mild cam.
I can't find the dyno sheet that just shows my old car alone, but I posted the one that shows it comapred to my new ride. It was 182/130
https://honda-tech.com/zerothread?id=163126
do the A's like high compression as much as the B's and C's?
i plan on running:
Toda A's
Spoon 2ly HG
Spoon Header
Skunk2 Mani.
AEM CAI
not sure what exhaust.
i will eventually upgrade to higher comp. pistons but not anytime soon
i plan on running:
Toda A's
Spoon 2ly HG
Spoon Header
Skunk2 Mani.
AEM CAI
High compression always helps but isnt quite as necessary with spec As as needed
with larger cams.
93B18
Jun 20, 2001 11:00 AM
! Thanks Mike and RealtypeR. Can anyone give me personal experiences with Toda A's?
