00 si won't start!
Old May 25, 2006 | 03:18 AM
FastReligion's Avatar
Default 00 si won't start!
my friends 00 si won't start, it has fuel, and spark, but for some strange reason it doesn't start, it turns over and sparks and there's fuel leaving the return line, but it just won't start, any other suggestions?
Old May 25, 2006 | 03:20 AM
fmrprojects's Avatar
Default Re: 00 si won't start! (FastReligion)
the timing is off, see if it skipped a tooth
Old May 25, 2006 | 09:18 PM
Simple's Avatar
Default Re: 00 si won't start! (fmrprojects)
an engine needs...
compression
timing
fuel
spark
.. if its missing one, it wont start. if it has fuel and has spark, check the timing, if the timing is factory, check your compression...
also, if your coil is out, it will still allow the spark to jump the gap on the plug, but loses its spark under compression... check and make sure the coil is good... if its got any black/brown spots... it got no sparky
civicgsr95lsd
Nov 24, 2013 09:24 PM
scotty.b16a1
Jan 2, 2013 04:54 AM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
kelviiv
Dec 17, 2008 11:19 AM
t3to4e
Jan 7, 2004 05:00 AM
