F22A Crank Pulley on a H22A (searched)
Old May 25, 2006 | 03:05 AM
skinnyboy's Avatar
Default F22A Crank Pulley on a H22A (searched)
Also posted in the Prelude forum but not many answers there either, Havent had a definative answer to this as yet but any conversionists out there who converted a F22A accord/lude to a H22, did you use the F22A crank pulley for your accessories?
Reason i ask is i want to use my F22A PS/AC/Alt. but the belt and pulley is a 4 rib where as the crank pulley on my H22A is a 5 Rib. Can I swap the F22A one onto my H22?
Also thought i'd ask, is the H22a crank pulley a balanced pulley? Mine ahsabout 5 holes drilled on one side i was wondering if this might preclude me from using the F22A one which hasnt got the holes.
Cheers
Mark
Old May 25, 2006 | 09:44 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: F22A Crank Pulley on a H22A (skinnyboy)
The h22a crank pulley slides on the F22A fine matches up you need to use the F22A bolt though if you using the F22A crank...
pcguy760
May 3, 2007 09:29 PM
skinnyboy
May 27, 2006 08:54 PM
H23AHybridEG
May 23, 2004 01:46 PM
pablum
May 7, 2003 08:24 AM
