Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
HELP!!
Old May 24, 2006 | 11:43 PM
LIV3's Avatar
Default HELP!!
Hey people! i currently own a 2001 model Honda CRV thought i have some sort of interior light problem. i am not sure wat the problem is thought i have tried to turn them on and they didnt work. any one know y? ive replaced all light bulbs and checked the fuses.
ive asked around aswell and people said it may be:
the "main" switch - which i dont know wat it is or where to find it
the actual assembly/circuit
the connection from the socket to the bulb is not too good.
the screw that holds the unit to the roof panel..this screw creates the earth for the circuit
thanks in advance for any advice
Old May 26, 2006 | 05:40 AM
Ross 2.0's Avatar
In a Junkyard near you.
check the switch inside of the drivers door on the B pillar. those can sometimes seperate. If you can push it in with little to no resistance then you need to remove that part of the switch and pull out the part that has fallen into the B pillar.
user 8508202243
Apr 29, 2012 03:33 PM
lpdrumer
Feb 20, 2011 04:25 PM
aLaRcOn_87
Lighting
Dec 2, 2007 11:46 AM
Boarderx192
Aug 30, 2005 05:13 AM
Neptune
Feb 1, 2004 06:17 PM
