camshaft seals h22a
Old May 24, 2006 | 08:33 PM
OuttaGas's Avatar
Default camshaft seals h22a
has anyone ever had an issue with camshaft seals on a h22a turning inside the housing they sit in? i just had a set of seals fromt the dealer and they was loose inside. so then i went to orielly's to get some more since the dealer was closed and they did the same thing.
Old May 24, 2006 | 08:34 PM
mgags7's Avatar
did you get my last reply before that thread got deleted?
make sure there is no oil in there when you drive the seals in
Old May 24, 2006 | 08:37 PM
OuttaGas's Avatar
Default Re: (mgags7)
they was bone dry. the seals that came out fit perfect.the ones going in slide in with ease so i pulled them back out and slide the others back in and had to actually push them in with a lil force. the old ones had #'s on them
old #'s on seal was 29 43
new #'s on new seal was 28 42
Old May 24, 2006 | 08:48 PM
mgags7's Avatar
it should be more than a little force man, something is wrong, are you sure the cam caps are tight???
you should have to use a driver or a big socket or something to hit them in....
Old May 24, 2006 | 08:52 PM
OuttaGas's Avatar
ya triple checked those. that was the first thing that came to mind.
Old May 24, 2006 | 08:54 PM
mgags7's Avatar
then i would say you have the wrong seals.....
Old May 24, 2006 | 08:56 PM
OuttaGas's Avatar
ya its just wierd that the dealer and orielly's sell the wrong "same size" seals.
Old May 25, 2006 | 04:47 AM
mgags7's Avatar
Default Re: (OuttaGas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OuttaGas &raquo;</TD></TR><TR><TD CLASS="quote">they was bone dry. the seals that came out fit perfect.the ones going in slide in with ease so i pulled them back out and slide the others back in and had to actually push them in with a lil force. the old ones had #'s on them
new #'s on new seal was 28 42</TD></TR></TABLE>
well both numbers are smaller so that suggests something to me.....i would take the old ones to the dealer and get them to match them.....when im getting parts for my jdm h22 i always ask for 1994 prelude vtec parts, it has always worked, and i replaced everything on that motor before it went in....
4.8t
Apr 5, 2010 08:03 PM
shaylude
Apr 25, 2007 06:12 PM
OuttaGas
May 24, 2006 10:39 PM
