installed some new brake calipers - not stopping well...
Old May 24, 2006 | 04:15 PM
EngineNoO9's Avatar
Default installed some new brake calipers - not stopping well...
what are some ideas why... My ideas are that there's still air in the line, possible kinks in the lines and stuff on the pads (when I got the calipers brake fluid had leaked everywhere and gotten on everything including the pads...)... any other ideas? I've done brakes tons of times before and this is the first time I've had issues
Old May 24, 2006 | 04:34 PM
Bud's Avatar
Bud
New User
Default Re: installed some new brake calipers - not stopping well... (EngineNoO9)
What does the lever pull feel like? What kind of calipers did you switch to?
Old May 24, 2006 | 05:00 PM
EngineNoO9's Avatar
Default Re: installed some new brake calipers - not stopping well... (Bud)
gixxer 1000 6-pot brakes and a bigger MC. lever doesn't feel completely firm like it should... I gave up since I'm still mega tired and have tomorrow to work on it
Old May 24, 2006 | 05:10 PM
thehondabuddy's Avatar
im guessing air in the lines. is it spongy feeling?
Old May 24, 2006 | 05:32 PM
marmaladedad's Avatar
If the brake fluid got on the brake pads, you can kiss the pads goodbye. Get new ones.
Old May 24, 2006 | 05:49 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: (marmaladeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">If the brake fluid got on the brake pads, you can kiss the pads goodbye. Get new ones.</TD></TR></TABLE>
+1.
Aldo make sure you get all the air out of the lines and use some brake cleaner to clean everything up nice.
Old May 24, 2006 | 06:11 PM
EngineNoO9's Avatar
Default Re: (RebornGSR)
argh... I'm not sure these galfer ones he sent are ok then... brake fluid got absolutely everywhere... that might be the problem...
Old May 24, 2006 | 07:25 PM
My question is, who in their right mind sends calipers, lines, and an MC WITH fluid still in them??
Old May 24, 2006 | 07:31 PM
EngineNoO9's Avatar
the reservoir was half full.... I'm kinda bummed but the deal for the brakes was still good. I'll see if the lines have air in them and then I guess I'll goto the shop. Guess this is a good way to keep me off the bike until I get the new CCT's in
Old May 24, 2006 | 07:41 PM
ngng's Avatar
Default Re: (EngineNoO9)
bleed the brakes,check the pads
Old May 24, 2006 | 07:46 PM
EngineNoO9's Avatar
Default Re: (ngng)
yeah I'm gonna do that tomorrow. once these are working it should be stoppie time. heh
Old May 24, 2006 | 07:50 PM
It'll always be one thing after another - brake lines, and then the CCTs, and then the fork springs, and then the RR, and then ...
Stoppies, huh? But how's that gonna make you go faster??
Old May 24, 2006 | 07:52 PM
EngineNoO9's Avatar
I already have a red superhawk. don't need to go any faster. do need to order my racetech stuff and call the guy about the rear shock - see if he can rebuild it. my RR is safe. it's a gixxer 750 one. Imagine that a suzuki part being better then a honda
Old May 24, 2006 | 07:56 PM
Suzuki stuff is much better than Honda - squids who ride Suzukis constantly crash-test ALL the components.
Old May 24, 2006 | 07:58 PM
EngineNoO9's Avatar
lol
Old May 24, 2006 | 08:00 PM
Damn. It's hard to keep up on two different forums to respond to the same topic.
Old May 25, 2006 | 11:50 AM
EngineNoO9's Avatar
argh I'm so ******* frustrated right now... I spent the last couple hours taking things apart and rebleeding them and it still doesn't feel solid. I'm out of ideas and have wasted about $20 worth of brake fluid already... anyone near blacksburg, va good with brakes and wanna help?
Old May 25, 2006 | 12:02 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
If the lever action is firm, and they still dont bite. Its the pads.
Old May 25, 2006 | 12:03 PM
EngineNoO9's Avatar
Default Re: (Rguy)
I know. lever isn't firm though...
Old May 25, 2006 | 12:05 PM
Rguy's Avatar
25 Year Member
Community Builder
Could just be how 6pot calipers are supposed to feel, but im not sure since i have no experience with them.
Old May 25, 2006 | 12:08 PM
EngineNoO9's Avatar
Default Re: (Rguy)
does anyone have any tricks for bleeding brand new systems? I've ran my brakes dry before when bleeding but this is diff... My old bike I even rebuilt the caliper and got it working fine. this just doesn't seem to want to be nice one issue that I'm having is I had to seperate the pads some to fit them on which means I have to get the pads seated right with respect to the rotors.... I'm not sure if I'm doing it right
Old May 25, 2006 | 04:25 PM
Grumpy Old Man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EngineNoO9 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone have any tricks for bleeding brand new systems? I've ran my brakes dry before when bleeding but this is diff... My old bike I even rebuilt the caliper and got it working fine. this just doesn't seem to want to be nice one issue that I'm having is I had to seperate the pads some to fit them on which means I have to get the pads seated right with respect to the rotors.... I'm not sure if I'm doing it right</TD></TR></TABLE>
Your going to have to let the air come out of the lines and that takes time.
Assuming you have some pressure pull the lever firm then use something like a ziptie to hold it firm for a few hours. I bet when you come back a big bubble comes out when you bleed them.
You can also tap the lines to try and loosen up any bubbles that are stuck.
Old May 25, 2006 | 04:58 PM
EngineNoO9's Avatar
zip tie it with the cap on the reservoir? I may do that....
Jizzmaster Zero
17
Mar 3, 2007 10:04 PM
Tutin77
Sep 18, 2004 09:42 AM
Ex-ITR5874
Jun 25, 2004 09:51 AM
NammyBoy
11
Nov 29, 2002 12:00 PM
d0nkeyxPunch
Oct 26, 2001 09:28 AM
