Tried reseting SRS, but SRS light blinks
I just tried to go out and reset the SRS light in my 95 accord. I put 2 paperclips in the yellow 2 pin connector under the dash, connected them together and turned on the ignition and all it does is blink continuously without stopping. The proceedure says it blinks twice and then goes off then you can continue, but mine just blinks and doesn't stop. Help!! TIA
first off did you fix the problem if not it will come back on.
second the procedure is jump the mes untill the srs blinks then within 4 second jump again then take out. then wait for srs to stay solid then turn off.
Yes the problem is fixed.
So you are saying when it starts blinking disconnect the MES loop, then reconnect and then disconnect wait for it to stay solid and then turn it off?
PaulRi
Dec 8, 2015 05:29 PM
technine
May 25, 2006 03:05 PM
