will it work?..
Old May 24, 2006 | 02:28 PM
hatchlvr's Avatar
Default will it work?..
alright so i have a 91 civic hatch with the 4 speed manual transmission and i was wondering if i got an 88 crx si 5 speed transmission and swaped it into my hatch...will it fit? cause i heard somewhere that they both had diff splines
Old May 24, 2006 | 06:16 PM
antivic's Avatar
Default Re: will it work?.. (hatchlvr)
should bolt up, but ur probably gonna need si axles.
Old May 25, 2006 | 09:20 AM
nelsmar's Avatar
why would you need si axles?
i started with si tranny in my si. it died. put a 4 speed in for temp. and now i have si again. if you use diff axles you need diff hubs to match. input shaft should be fine... shouldnt have a problem. almost seemslike there was a problem with matching up the input shaft - > clutch
Old May 25, 2006 | 01:01 PM
hatchlvr's Avatar
alright...thanks guys
scottso990
Nov 3, 2010 07:22 AM
LurkerS8
17
Jun 25, 2005 07:46 AM
gutted-dx
Mar 4, 2005 10:04 AM
Red_Si
11
Dec 21, 2003 09:54 PM
JStone2775
Aug 20, 2002 11:16 AM
