Can someone please post pics of where on the car I can mount jack stands
Old May 24, 2006 | 01:29 PM
TehMoonRulz's Avatar
Default Can someone please post pics of where on the car I can mount jack stands
One of those stupid little things I havn't figured out yet. Thanks!
Old May 24, 2006 | 02:01 PM
jacoop86's Avatar
Default Re: Can someone please post pics of where on the car I can mount jack stands (TehMoonRulz)
i dont know about pics and i dont have my digi camera right now so i'll just tell you. on all the cars i've seen you can put them under the frame, behind the front tires and in front of the rear. you'll see a little peice of metel that sticks out more than anything else around it, its right there. also you might be able to use a stock crossmember and the metel that the rear tow hook is connected to. if you have any doubt look in your owners manual or download a shop manual, its in there. if you cant find one look in the fist couple stickied theads at the top of the forum.
Old May 24, 2006 | 03:14 PM
Mr_CRX's Avatar
Default Re: Can someone please post pics of where on the car I can mount jack stands (jacoop86)
This is the only picture I have of that area.. If you look in this spot behind the front wheels (there's also one in front of the rear wheels as well) You will see a tab stickign down about 1/2" lower than the rest of the car, that's about 3 inches long. Use that location for the stands.
Old May 24, 2006 | 03:18 PM
Mr_CRX's Avatar
Default Re: Can someone please post pics of where on the car I can mount jack stands (Mr_CRX)
Here we go... this pic is better
Old May 24, 2006 | 04:32 PM
ILcrxsi1's Avatar
I tell doctors what to do
right on the ole jimfab traction bar in the front
Old May 24, 2006 | 05:48 PM
civic_dork's Avatar
Default Re: Can someone please post pics of where on the car I can mount jack stands (ILcrxsi1)
my 2 cents
if you're using a floor jack:
i cut a 2x4 piece of wood about 5 inches long. then i cut a groove in it so that the "piece hanging down further than the rest" doesn't get smushed when jacking on it.
before that i just put a piece of 1/2" plywood inboard of that spot and jacked on that, that worked also.
if you're using the jack that came with the car... that 'notch' is already there.
Old May 24, 2006 | 08:40 PM
408wdy's Avatar
Default Re: Can someone please post pics of where on the car I can mount jack stands (civic_dork)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_dork &raquo;</TD></TR><TR><TD CLASS="quote">my 2 cents
if you're using the jack that came with the car... that 'notch' is already there.</TD></TR></TABLE>
you user name doesnt lie you really are a dork lol... just jack it up from the front then put stand on each side
xyooj
Oct 30, 2002 09:25 PM
underrated99si
Feb 10, 2002 05:20 PM
Chronicsinners
Feb 4, 2002 07:44 PM
Balls
Jan 20, 2002 07:59 PM
